Thank you for your inquiry, friend!
Based off the information you have provided your Frigidaire washer keeps filling with water then will spin out and shut off. This sounds like an issue with your water valve or control panel. I would recommend performing a reset on your washer and you can do that by flipping the household circuit breaker off for at least ten minutes. If that does fix the issue you may want to have a professional technician out to perform a proper diagnosis. Hopefully this is helpful information. -Matt
Thank you for your inquiry, Judy Mudgett!
From the information you have provided your Frigidaire washer is displaying 11 minutes and lights are blinking. Sounds like you may have a possible issue with your control panel or miscommunication. I would suggest resetting your washer and you can do that by unplugging the power cord for roughly ten minutes. If you continue to have a problem with your display I would suggest having a professional technician come out and perform a proper diagnosis and repair. Hopefully this is helpful. -Matt
Good Morning Shawna Midkiff, thank you for your post!
From my understanding the lid for your Frigidaire top load washer is not remaining up. It sounds like you could have a possible issue with the hinges. I would consult with a professional technician to have them come out to accurately diagnosis and repair your washer. Hope this helps. -Matt
Hey friend, thanks for your post!
Based off the information you have provided it sounds like there could be a buildup of soap within your appliance. I would recommend performing a clean cycle on your appliance which can be done by using a hot wash cycle and a cup of bleach. I hope that helps to some degree. -Matt
