I was just reading everyone’s comments regarding not being able to find the Emerson LC320EMXF 32′ LCD TV code for the Comcast DC50X Digital Transport Adapter. I’m using the Sylvania code of 11864 and the Comcast DC50X remote seems to work fine. Hopefully it’ll work for you as well.
I called comcast an they help me with the remote even though my remote was a xfinity remote with this tv it was totaly different setup from the instruction mr remote code was 10171 thanks
If your direct Tv remote is an RC 64 it won't work. You need to find an RC 65. I was told that will fix your problem for Direct Tv and Emerson.
10154, 10236, 10463, 10180,
10178, 10171, 11963, 11944,
11929, 11928, 11911, 11394,
10623, 10282, 10280, 10270,
10185, 10183, 10182, 10181,
10179, 10177, 10158, 10039,
10038, 10019
You haven't specified the model number of remote control you possess; that is why I send this remote controls codes.
[1] Locate the 5-digit code for your DIRECTV® Receiver
[2] Power on the DIRECTV Receiver
[3] Slide the MODE switch to the DIRECTV position
[4] Press and hold the MUTE and SELECT keys until the
green light under the DIRECTV position flashes twice,
then release both keys
[5] Using the number keys, enter the 5-digit code. If
performed correctly, the green light under the
[6] Aim the remote at your DIRECTV Receiver and press
the PWR key once. The DIRECTV Receiver should
turnoff; if it does not, repeat steps 3 and 4, trying each
code for your brand until you find the correct code
OK.
