Vertex Vx-4000 . Vx-5500. Vx-6000 Programing Software Ce-49 Logo
A
Anonymous Posted on Mar 17, 2014
I need C49 programming software - Vertex Vx-4000 . Vx-5500. Vx-6000 Programing Software Ce-49
Daniel Jacobsen
Level 1:
New Friend:
Welcome Back:
Visited the website for 2 consecutive days.
  • Contributor 4 Answers
  • Posted on Apr 05, 2015
Daniel Jacobsen
Contributor
Level 1:
New Friend:
Welcome Back:
Answers
Questions
0
Helped
2978
Points
16
E studio 520 code c447
All error code soloution of fuser unit Fuser Unit Error Status Counter
Purpose
When a fuser unit related error (error code C41, C43, C44 or C45) occurs, the set value of the fuser status
counter varies, depending on type of error.
Displaying and checking the set value of the fuser status counter can analyze a cause for the error. If
any of "2 to 9" is set at the fuser status counter, the fuser unit will not be operated for safety reasons.
After the fuser unit related error is resolved, if "0" is set, the fuser unit will be operated as usual. If any of
"10 to 19" is set at the fuser status counter, the fuser unit will be operated as usual, even if "0" is not set
after the fuser unit related error is resolved.
C41: Thermistor or heater abnormality at power-ON
C43: Thermistor abnormality after abnormality judgment
C44: Heater abnormality after abnormality judgment
C45: Thermistor abnormality during printing
C46 to C49: Reserved
Description
When this code is used, the current set value of the fuser status counter is displayed. Only "0" can be
manually entered, in order to restore the fuser unit to its normal operation, after the fuser unit related
error is resolved.
For further reason why the counter value differs despite the same error code, refer to 5.1.7 or 5.1.8
[Fuser unit related service call] in the Service Handbook.
0: No error 10: C47 (Reserved)
1: C41 (Once) 11: C47 (Reserved)
2: C41 (Consecutively occurs) 12: C48 (Reserved)
3: C46 (Reserved) 13: C49 (Reserved)
4: C43 14: C47 (Reserved)
5: C44 15: C48 (Reserved)
6: C45 16: C49 (Reserved)
7: C44 17: C47 (Reserved)
8: C45 18: C48 (Reserved)
9: C44 19: C49 (Reserved)
* Default: 0
Setting Timing
Use this code to resolve the fuser unit related error (error code C41, C43, C44 or C45). Resolve the
error, and set "0" (or reset the counter), in order to restore the fuser unit to its normal operation.
Caution
Remember to resolve the fuser unit related error, and then reset to "0." also 447
Error code c43
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
2helpful
Call for service C 430
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
2answers
Join software group download yahoo
The software program is KPG-35D and you need a cable that is KPG-36. I can't help you with the software because it is copyrighted by Kenwood. You should try looking in the Yahoo Groups section for a programming group or Kenwood group. Many have found the road to enlightenment doing so (if you get what I mean).
3helpful
TOSHIBA E STUDIO 207 ERROR C 44
Purpose
Description
error is resolved.
* Default: 0
Setting Timing
Caution
How to zoom in on pics you are taken?
if you have saved them to your computer in my pictures right click on the photo select open/preview there should be a zoom tab this may vary depending on your operating system in xp you will see a magnifief with a plus+ and minus - in the lower tab of the photos
hope this helps
Erorr code c49 in di470 photo copier
Hi this error code is an issue with paper source option vertical transport cooling fan motor or the control board check and replace motor if it dose not resolve the issue change the control board If you check vertical transport cooling fan motor rotation the voltage across pj14a-3 on power supply board and ground is dc0v after malfunction os reset
if yes change control board if no check cooling fan motor and replace it
Top Vertex Radio Communications Experts
eradiostore
eradiostore
k24674
John
John
Are you a Vertex Radio Communication Expert? Answer questions, earn points and help others
