Timex 27191 Wristwatch Logo
A
Anonymous Posted on Mar 16, 2014
How to fix eyeglasses - Timex 27191 Wristwatch
How can i open the battery hatch of my nike WC0070?
You are going to need a small hex screwdriver something you can sometimes find in an eyeglass kit.
3helpful
I changed the battery in my timex expedition watch, and now the alarm doesn't sound. The watch is set for Beep ON, but it never beeps.
Same thing happened to me, took watch to watch shop, they changed the battery and the chimes stopped working. Simple fix, the faceplate was put back on wrong. Unscrew the face plate and turn it upside down (or right side up depending on your POV) the circle on the inside of the faceplate will line up with the springs inside the watch and the chimes will start working again. If you have a pair of eyeglasses screw drivers, like I did, you can do this yourself.
Feb 12, 2011 • Watches
How do I get the back off?
You can use an eyeglass repair kit screwdriver. They are a very small thin flat-head that is used to take these off.
Nov 10, 2010 • Watches
A screw came out my Bvlgari sunglass where can i get them repaired in long island?
mcdevito75 here, Most Dollar stores carry an eyeglass repair kit containing screws, screwdriver and a magnifying glass if you"d want to replace that screw your self, Or, you can see any eyeglass outlet in your area.
2helpful
HOW DO YOU OPEN CASE ?
Take an eyeglass and carefully examine watch case back all the way around. You will find tiny groove or ''lip''. This is exact place where to insert blade and pry up. Rate me, plz.
2answers
Timex datalink usb changed battery then lost beep fonction
Sorry, I don't have a solution, but I just wanted to share that I have had the same exact problem twice. But I got a watch repair place to replace the battery.
I need to rezise my bracelet on my eco drive
You will need an eyeglass repair kit screwdriver or pick to remove pins and remove the link or add a link
Have a Kenneth Cole watch and the battery needs replacing. The watch is a KC1239. Any solutions?
Get a flathead screwdriver from eyeglass kit and the back cover will pry off to replace battery
Need a new stem. Can I purchase on and get it put on myself
You have to open your watch and find movement number. Use an eyeglass as the numbers are very tiny. Number is pressed onto one of movement plates and shoud be letters ETA+number.
When this is done, visit your nearest watchmaker shop and ask for stem for movement ETA+number. Do not tell this is for Ebel or you will be charged accordingly to brand name.
There should be no problems for supplying ETA stem.
Top Timex Watches Experts
Paul Bade
NOEL
NOEL
Ngoro
Are you a Timex Watch Expert? Answer questions, earn points and help others
