This could be the valves not opening all the way that could be due to mineral buildup, check the water pressure in the line and also check to make sure the proper voltage is getting to the valves and if all is ok, replace the valve assembly from any online spares centre.
1. First, check that the tap is not accidentally turned off.
2. Check that the gray water inlet hose is not squashed or kinked lies.
3. It is also possible that the filter is clogged in the supply hose. Close the tap and disconnect the hose. Here is some pressure on it, so keep a towel handy. Check the filter that output waterklraan, and clean it if necessary.
The most common cause of a fault "i10" is closed valve on the water supply line. So this failure indicates a problem with filling of water.
Possible error causes:
Closed water tap, Inlet valve faulty, inlet hose bent, softener system clogged, pressure switch or pressure switch hose obstructed or leaking, wiring from pressure switch to printed circuit board (PCB), wiring from inlet valve to PCB and finally PCB.
Check that water and power are switched on properly, and that inlet hose is clear. Check manual first, if no answer or this doesn't fix, then contact manufacturer or service agent.
I have a similar issue on oko favorit 50700. I have checked the flow from the inlet hose into a bucket and it really seems ok, so I think maybe a problem at the inlet to the machine? Plea update if you get a fix!
You will need to type into your search engine 'aeg washer manual' and you should be presented with a number of sources from which you can either download a manual for free or have to pay a nominal amount. During the process you will be asked for the actual model number!
