SOURCE: not cooling
hi thanks for the question is the compressor running hot if its not hot and the fan by the compressor is running the problem is that the compressor is not starting check the compressor you might need a new start relay mounted on the compressor thanks the appliance doc
SOURCE: Condensor fan runs but the compressor wont start
Either you have abad comoresor or abad compresor relay ,i will try to replace the relay first(if you don't have away to check the compresor) wich is cheaper (about $20 for the part)If doesn't work the compresor is burned or stuck.
SOURCE: Compressor and Compressor Fan Not Working
Rotate the dial on the defrost thermostat, a big click is when it goes into defrost, a little more and it should turn the compressor back on. By overload protector, do you mean the one under the compressor cover?
SOURCE: side by side not cooling
Check your compressor relay-
http://www.acmehowto.com/howto/appliance/refrigerator/check/compressorrelay.php
