How do I find the ! button on my TI-89 plus silver edition?
SOURCE: cant play games on calc
This probably is not a problem with your calculator. A syntax error is caused by the program you are running. It just means that the game you have downloaded has a bug in the code and is unplayable. Check out TiCalc.org for a lot of working games and programs.
SOURCE: TI-83 Plus Silver Edition problem
Use a paperclip (tiny hole on back of caculator) and reset.
JC
SOURCE: ti 84 plus silver edition language change
The easiest way to fix this is through the Apps menu. Hit the apps key, then scroll down until you see any language(espanol, Deutsch, etc.). It should give you the option of switching to either that language or restoring to English. I just tried this on a calculator that was set to German. I hit Apps and scrolled down until I recognized the option for Spanish, and it still worked. It let me switch back to English.
Hope this works for you.
SOURCE: Find the antilog on the TI-84 Plus for finding pH in chemistry problems
I'm not specifically familiar with the TI83 or TI84 but I've used a lot of TI calculators in my time, so I'll give it a try. If your trying to find the antilog of a number in base 10 enter the number and hit the (10 to the X) button. If you're trying to find the antilog of a number in in base e (natural log), enter the number and hit the (e to the X) button.
SOURCE: frozen ti 84 plus silver edition
Ther is no reset button. You have to take the batteries out.
Take the AAA batteries out and take the back up battery out...located in a little door with a screw just above the AAA batteries. Leave the batteries out for about 8 hours. This is how you reset a TI graphing calculator.
