SOURCE: where can I get a
Se if you can get the wire to sit in the pisition ware it looks likely that was when it was new it has a natural shape or bend to it If you can;t find the point whare it was origanly its a ground so as long as its hooked to the engine or frame it should work because the whole machine is grounded and it sounds like this is the ground for the kill switch
SOURCE: How do you start the
use the primer bulb bulb and press it three times to fill the carburator with gas,then push the choke rod to the full right position and either start it with the pull rope or use the electric starter to start it,if it will not fire,then you have carburator problems, then remove the sediment bowl off the bottom of the carb and see how much junk is in this bowl and dump out,then reprime if needed, and then try a small amount of gas into the carb and see if it fires,if so then you need the carb cleaned out depending how plugged with gunk it is by either yourself or a professional,i own 3 of these machines and the gas they have now(especially) the "gasahol" E-10/E-15 blends are tough on these carbs,let me know how this works for you,and see if we can get this unit running for you!!! GREAT MACHINE when running!!!
SOURCE: I was given a Toro
If you replace the carburetor needle seat and bowl gasket it will do the trick. Look up your model snowblower at www.arcolawn.com and you can have them shipped.
Good luck
joe
