Garden Logo
Rodney Atwood Posted on Dec 15, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Starts but only runs for two minutes it's a toro 521 snowblower
Kelly Buxton
Level 2:
Sergeant:
  • Expert 322 Answers
  • Posted on Dec 17, 2013
Kelly Buxton
Expert
Level 2:
Sergeant:
Answers
322
Questions
Helped
137199
Points
509
When it dies will it restart right away or do you have to let it cool down first? It sounds like it could be the ignition module if that is the case
If you need further help, I’m available over the phone at https://www.6ya.com/expert/kelly_69a0cf1b13789df1
3 Related Answers
JOHN LAPIER
  • 2602 Answers
  • Posted on Nov 21, 2010
SOURCE: where can I get a
Se if you can get the wire to sit in the pisition ware it looks likely that was when it was new it has a natural shape or bend to it If you can;t find the point whare it was origanly its a ground so as long as its hooked to the engine or frame it should work because the whole machine is grounded and it sounds like this is the ground for the kill switch
Anonymous
  • 2468 Answers
  • Posted on Jan 28, 2011
SOURCE: How do you start the
use the primer bulb bulb and press it three times to fill the carburator with gas,then push the choke rod to the full right position and either start it with the pull rope or use the electric starter to start it,if it will not fire,then you have carburator problems, then remove the sediment bowl off the bottom of the carb and see how much junk is in this bowl and dump out,then reprime if needed, and then try a small amount of gas into the carb and see if it fires,if so then you need the carb cleaned out depending how plugged with gunk it is by either yourself or a professional,i own 3 of these machines and the gas they have now(especially) the "gasahol" E-10/E-15 blends are tough on these carbs,let me know how this works for you,and see if we can get this unit running for you!!! GREAT MACHINE when running!!!
barterjoe
Joseph Mueller
  • 346 Answers
  • Posted on Feb 14, 2011
SOURCE: I was given a Toro
If you replace the carburetor needle seat and bowl gasket it will do the trick. Look up your model snowblower at www.arcolawn.com and you can have them shipped.
Good luck
joe
Changing the belts on toro 521 snowblower
I don't think this qualifies as a camera question, does it now ? Try posting your question in a forum dealing with outside machinery.
Jan 12, 2017 • Cameras
Toro 521 snowblower starts but only runs a minute
hello
fuel filetr is blocked or spark plug is shorting
replace the plug then run it
injoy
Dec 15, 2013 • Garden
Toro 521 snowblower wont run, cleaned carb but need factory specs for settings
bottom jet is 1.5 turns out from lightly seated and the side jet screw is 1 turn.
Nov 07, 2017 • Toro Garden
I was given a Toro 521 Snowblower. It won't start. I replaced the plug, gas filter, air filter and gas line. Still won't start. Also drained the tank and added new gas
Good luck
joe
Feb 14, 2011 • Garden
Toro 521 snowblower instruction to replace belts
Remove bottom cover(4bolts) 3/8"Remove plastic housing cover (mine had 2 bolts)3/8"Loosen belt guide bolt.1/2" rotate guide away from belt.I used a pipe wrench to hold main shaft and removed drive pulley.Replace drive belt as you return pulley onto shaft.Replace auger belt.Align belt guidesSet handle adjustmentsReplace coversTest and hope for warm weather, I live in BuffaloHope this helps
I have a toro 421 snowblower i filled it up today with oil and gas when I started it a milky white oil looiking came out the breather tube what could have caused this
it sounds like you had water in the crank case.
Stop running it immediately and drain all the oil. Then make sure the crank case is empty of oil and clean, and refill with fresh oil. After you fill it back up with oil, run it a minute and check again for any milky/foamy oil. If it is clean, check it again after several minutes. If it stays clean, you should be good. If it is milky again, take it for professional service, as you probably have a damaged gasket somewhere.
7helpful
2answers
Toro 521 snowblower..nn replace gas line to carb, it runs inside the engine cover..removed all bolts but the back cover doesnt seem williing to be removed
Or, you can try the easy approach. Take a 1/4" bolt about 2" long and cutoff the head. Force the bolt into the old fuel line on the fuel tank side (after removing fuel tank), push other end into new fuel line, tape the lines together well with electrical tape. Gently pull from one side and push from the other until new section of line comes through. Just did this and it too all of 5 minutes.
Top Garden Experts
Jay Finke
Jay Finke
john h
