Total repair time < 5 minutes
1. Unplug washer
2. Remove top from washer using 9/32" socket wrench (3 screws in back)
3. Locate the white connector panel on back
4. Remove 3rd connector from right in the connector panel
(1st from right has 2 wires in it, 2nd from right has 2 wires in it, 3rd from right as 4 wires in it -- all of the wires into my connectors are pink)
To remove, push down on top 2 pins then pull out
5. Put the connector back in.
6. Replug in washer and watch it work.
7. Get a sharpie an mark "F/DL" above the connector -- you will be glad you did
8. Put top back on
9. Comment here that "it fixed it for me"
10. Do something nice for someone today -- even just a smile for someone looking down.
I have to do this once every 9 months with my heavily used washer (I have 4 kids).
Hope this works for you.
Worked perfectly! I couldn't believe all I had to do was unplug and replug! Thanks!!
Thank you, thank you, thank you! I have already replaced the lock mechanism, reinstalled it three times, unpluggged, replugged, wiggled everything...nothing has helped. This worked perfectly! I wash about to buy a new washer for holiday guests. You made my day! Laura in Arizona
Worked great....But why? LOL
Thank you! So simple. Worked right away. You saved the laundry day.
"Fdl" is a door latch fault code. When you intially start the washer, the door will make several attempts to lock. If the Central Control Unit (CCU) does not detect a door lock, the fault code is generated. The CCU is the main computer (brain) of your washer. This generally means you have a bad door latch. The following link explains how to replace one:
http://www.fixya.com/support/r587965-door_latch_replacement_fdl_error
You may try unplugging the washer for at least 30 minutes, first. This will reset the CCU and clear the fault code in some cases. Some of these faults can be erroneous. If the fault code returns after a CCU reset, you have a legitimate problem.
If a replacment door latch is required, you may purchase a new one at searspartdirect.com, appliancepartspros.com, repairclinic.com, or pcappliancerepair.com. Just type in your model number for your search criteria. All these sites offer great service and have competitive pricing, so shop all of them for the best price. If you have any questions, please let me know. I hope you find this information helpful.
"dl" error code means that the ccu(central control unit) is not getting contact at door latch connection. replace your ccu and you will be good to go. bad contacts inside of ccu.
SOURCE: error code dLF
"Fdl" is a door latch failure error code. This is usually an indication that the door latch requires replacement. The manufacturer recommends unplugging the washer for at least 30 minutes to reset the computer. In some cases, the washer will experience momentary "glitches" and can be cleared using this method. You may also want to inspect the door latch wiring to ensure all the connector plugs are intact and not loose or broken. You can access the door latch wiring harness by removing the top panel of the washer. Removing the panel is simple. Just remove the three screws that hald the panel in place in the rear of the washer. With the screws removed, the panel will slide back, then lift off. Locate the door latch assembly behind the front panel on the right hand side. Trace all the connectors from the door latch to the Central Control Unit (CCU) and make sure they are properly seated at both ends. If these preliminary steps do not clear your problem, it is recommended that you replace the door latch. The following link explains how:
You can find a replacement latch assembly at searspartsdirect.com or repairclinic.com if you wish to order online. Just type in your complete model number. I hope you find this information helpful. Let me know if you require additional assistance. Hopefully you can solve your problem without requiring parts.
SOURCE: Front Loading washer Kenmore Ht3
Here are the steps to unlocking the door manually if clothes are still in the machine.
1.Unplug machine
2.remove bottom panel
3.Reach up along the inside of the front panel and locate the botttom of the door latch assembly
4.Located on the bottom of the door latch assembly is a tear dropped shaped tab
5. Gently pull down on the tab about a 1/4 inch or until a click is heard.
6. You may now open the door.
This code means the door lock mechanism has failed or the central control unit has failed. Replace the door lock mech. first. This should fix the problem. (before replacing anything make sure there is no obstruction around the switch or in the switch.) After the machine has been unplugged it may fix itself. if not replace door lock mech.
SOURCE: KENMOER HE 3T WASHER WON'T START IT SAYS DLF
1. Unplug washer.
2. Remove the outer portion of the door bellow. This is the gray rubber boot around the door. Feel around the edge of the door bellow where it attaches to the front of the washer. You will find a wire retaining hoop in the seam between the rubber and the front case. Follow this wire hoop to the bottom of the door bellow and you will find a tension spring. Carefully, stretch this spring apart and remove the wire hoop.
3. Pull the rubber bellow from the door facing on the front of the washer being careful not to rip or tear it. Once removed, fold the rubber backwards inside the drum so you can access behind the front panel. DO NOT remove the rubber bellow from the wash tub.
4. The door latch assembly is located behind the front panel of the washer on the right hand side. Locate and remove the three screws on the washer front that hold the door latch assembly in place. The whole assembly should come free from the washer front and be held by a plastic mounting bracket and several wire connectors.
5. Carefully remove the latch assembly from the plastic mounting bracket BEFORE attempting to unplug any wires. It makes it much easier to access if you do.
6. Unplug the wire connectors using care not to break any of the wires. You may want to write them down, but I believe they will only plug into their respective slots.
7. Remove the old door latch and install the new one in the reverse order of the steps I just presented to you. Plug the wires back in first, then place the whole assembly back into the plastic mounting bracket, and then reattach to the front of the washer.
8. Now, when you get the reinstalling the rubber door boot, you may want to get the assistance of a second pair of hands as it can be difficult sometimes to manipulate the wire retainer back into place. Carefully reattach the rubber bellow to the door facing on the front of the washer first.
9. Starting at the top of the door bellow at the 12 o'clock position begin inserting the wire hoop back into the groove. Work your way around with both hands to the 4 and 8 o'clock positions. (This is where you could use those second pair of hands). While holding a slight downward tension on the wire hoop to keep it in place, pull the tension spring apart enough to snap the remaining part of the hoop into place at the bottom. Once you've completed these steps make sure the door closes and latches properly. NEVER slam a door with an electronic latch. They can break easily.
Now plug the washer back in and test operate. NOTE: You can run diagnostics on these washers by referring to the tech sheet provided by the manufacturer. The tech sheet is located behind the lower panel under the door, or along the interior cabinet walls. Included, are instructions on how to run diagnostics and troubleshooting tips associated with the list of fault codes. It is recommended that this tech sheet remain inside the washer to prevent it from being lost.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: Constant dlf changed the handle still dlf 1/2 hour just to start
1. Unplug washer.
SOURCE: washer error code dlf
Hello and welcome to FixYa
DL f is a door lock error and is caused due to an
issue with the door lock when it is unable to lock/unlock. Please check the
door lock mechanism/door switch assembly and replace the part that has gone bad
so that the issue is resolved. Please get back to me if you have any other
questions.
Kevin
questions.
Kevin
