SOURCE: error openx menu dat error
Take all the memory contents out to your computer as backup, format your memory to fat32 and put all the memory contents again to the memory from your computer. If not working try downloading the card system files from the card manufacturer site, these files are needed to run the card just like the operative system in your PC, if these files get corrupt or deleted the card wont work.
SOURCE: Menu.dat issue
the _DS_MENU.DAT could not be found bcuz you guys probably deleted it or edited it accidentally. if you edited it, put it back to its normal self right away. for example, it was _DS_MENU.DAT.
if you edit it to look like, DS Menu.Dat , your R4 wont work. so fix it to its original self.
: ) pia
SOURCE: r4 couldn t find ds menu dat
Did you install the R4 kernel?
If you didn't click here, scroll to the bottom of the page and download the "English Kernel v1.8" (I'm assuming you want English).
1) Firstly connect your micro SD card and then extract all the files from the zip file and copy them all to the card.
2) Next put your .nds files, mp3 etc. onto the SD card (anywhere in the root of the card is fine).
3) Put your SD card into the R4, pop it into the DS/DSL and that should be it.
Hope this helps, any problems feel free to message me.
Regards,
SOD69
SOURCE: Hi by acident i deleted ds menu.dat for my r4 card
if you accidentally deleted the menu for the R4 menu try to reseat the card cartriage if that does not work you need to copy or install the system again
hope this help
