Re: How does water create electricity!!!!!!!!!!! KEEP...
Water is used to spin commutators in armatures of generators which in turn produces electricty. For example: Niagra Falls helps generat electricity. Do a search on Niagra Fall generators.
Do not wear wool to start with.Change the coat or pants fabric you are wearing.Next hold the metal door frame as you slid off the seat which will help keep you grounded.
Dry air and fabrics which create static electricity are a bad combo when exiting a vehicle.
Are you taking your cat for rides in the car? Why should it be a spray and not a pill or medicine? Do you keep the cat in a carrier while it is riding? Is the cat normally calm? It depends. I think there are tranquilizers that work on cats similarly to how they work on us, but of course the dose is different, and the neurological system of a cat has some big differences. I think they are taken in a pill not a spray, unless you want to tranquilize yourself at the same time. I wondered if the pet is fixed (spayed or neutered) because cats that aren't have more wild-acting tendencies.
Don't panic as that creates tunnel vision and you miss things that are right in front of you.. just keep calm and look around the screen, probably near your profile, or in the general region of where you log in or out of the email.. There will be a 'settings' or 'profile' page from where you may change your password.
1. Try this locate your goose neck its where your thermostat is located should be top hose comming from your radiator to your engine block. Tap on it lightly several times this might be made out of aluminum so don't go crazy on it.
2. Do this while it is hot but not over heating see it it fluxuates and it may calm down, sludge and gum builds up around the thermostat and causes it not to open (Or Sticks) CLOSED and creates pressure and heat it's letting the coolant circulate through the engine thus it can't keep the engine cool.
3. Question does the electric fans kick on, if it has electric fans? If not then the fan has a sensor check sensor loose connections and the ground is very important also make sure the fuse is not blown may have two fuses on on engine fuse block and one under the dash check both.
4. Mileage if its high miles car the radiator may be old depending on your situation may consider replacing it, replace the thermostat that usually is the culprit!
REMEMBER TO check coolant level!
5. But not always. Maintenance, Maintenance, Maintenance!If doing routine checks on your vehicle Isn't your bag of tricks then try your local jiffy lube or other lube shop. GOOD LUCK!
