Error Code C9 keeps on lightning even though i have changed the brushes (which where worned) and reset the program (acc. to instr. manual) i am suspicious about the print card is there a chance that there is a failure there? I cannot see any visual fail. What else should i look for Brgd Andrias Hansen Faroe Island
C9 is a motor fault.
Normally it's worn out carbon brushes so you'll need to check them first.
If worn out or broken, replace them.
Then, you need to erase the code (reset the machine).
To do this, turn the dial to off.
Press and hold together, prewash and soaking buttons.
While holding them, turn the dial 1 click anti clockwise.
Release the buttons.
Turn the dial to off, to any program and back to off.
This should get rid of the C9 code.
It will come back if you don't repair the motor fault.
SOURCE: AEG Oko-Lavamat 86820 Update Error code C9
Hello. I got error code C9 on a LAVAMAT 86800. It pumped in water, and it pumps out water. You can select pump in or out....But the motor dont turn. It will not sentrifuge. So I bought new carbon brush'es on the net. One of them were totally wore down. Now it works. They lasted for 10 years.
SOURCE: What means error code
C9 Indicates Motor Fault. It seems that the Carbon Brushes have Worn out.
Replace it and more likely it would Fix the Problem.Once you replace that, you need to put the machine into Service Mode to Reset the Error.
Steps for Reset the Error Code
1. Press and Hold the Prewash and Soaking Buttons Together.
2. Whilst Holding them, Turn the Dial from Off one Click Anti Clockwise
Note - If problem persists, Check the motor plug for broken wires and check the state of the carbon brushes.
Let me know, if needed further assistance.
Hope i helped you.
Thanks for using ' Fixya ' and have a nice day!!
SOURCE: Error C9
C9 indicates that the engine coal is worn out like brake pads on a
car. Re-new them. To reset the C9 error code after repair press in and hold the to upper left button. Rewind the program switch one step back from 0, release the 2 buttons and turn the program switch to 0 (zero). Now the machine error code has been reset.
Flemming Geisshirt, Denmark
SOURCE: What does error code c9 mean?
c9 means there is no motor movement, typically worn out motor carbon brushes.
