Baby carriers are best way of carrying your baby and keeping your hands free. While choosing the Manduca Baby Carrier, it is vital to check the age and size of your baby or you may end up getting the wrong one. The ones you buy should be specifically designed for the young babies. These factors are among the vital ones, which you need to consider while going for these carriers. For more details click here.
Did you clean the float switch water tube going into the water trough when the switch was replaced? Does it make 1 drop of ice,then shut off immediately? What is the age of the machine?
3 beeps every 3 sec. = Freeze Back Up Timer. Freeze > Specified Setting Yellow LED marked "F Timer" energizes. Check for F/S stuck closed (up), WV leaking by, HGV leaking by, PM not pumping, TXV not feeding properly, low charge, or inefficient comp. Dip switches 9 & 10 allow for factory adjustment of this back up timer feature.
It seems that the bulb in the front panel is pulling to much current as it ages and it makes the control panel in not work properly. Removing the bulb will fix the problem - just fixed mine.
Also seems to match your symptoms (works sometimes and then not others - bulb current is inconstent, light dims when dispense lever pressed - again wrong current draw).
