TSA lock on Eminent Osmosis Luggage, three digit TSA lock (HOW to change it to YOUR personal number)
Put the code numbers to '000' Take the lock levers OFF the lock Push the round opening button UPWARDS. IMPORTANT : KEEP holding the button UP until you have changed the numbers Change the TSA code numbers to what YOU want Release the round opening button Now your case combo lock numbers have been changed.
To lock the case put the two lock levers into the holes, spin the numbers and your case will be locked. To UNLOCK the TSA code spin the numbers to YOUR lock code, push the lock button UP and, hey presto, your case will open.
If you forget your NEW lock number you will NEED to go through ALL the numbers, starting at '000' to '999', to be able to open the lock/case. REMEMBER to PUSH the ROUND OPENING button UPWARDS on EVERY number change. Only THEN, when it finds YOUR correct three digit number, will it eventually open the suitcase/luggage/baggage. Good luck
The combination can usually be changed to one of the purchaser's own choosing but first read the instructions and carry out the adjustment before locking it.
Once locked the adjustment can't be made as if that was possible anyone would be able to reset the combination and unlock.
Fortunately few combination locks of the type are made to such a high degree of precision that by keeping pressure on the lock a sensitive touch can't "feel" the combination. It is an intuitive process but lots of patience is needed.
From prior Fixya answer:
The lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
Yoong queen,
You can able to open this number lock, but you show more patience,
put the lock number to 000 or 0000, then start with 001,002,,,upto 999 or 9999 if it is fourth digit. Each time you every digit give a slight pressure to the lever,,it will open with the correct number and open with that number you forget.
with regards
jaijith
By frequently resetting your lock combination, you decrease
the chance that someone will break into your luggage.
If someone watches you open your luggage at baggage claim
while going through security or at a hotel, they may break into your luggage
when they encounter you on another leg of your journey.
Change your lock after every major flight or trip to help
keep your items safe.
Avoid easy to guess passwords, as well, such as sequential
numbers, all the same number or birthdays.
Open your lock by inputting the current combination.
New Prestolocks have a factory set combination of
"0-0-0."
Turn the shackle 180 degrees.
Press the shackle
down and turn it 90 degrees to the left or right.
Input the new combination.
Move the shackle 90 degrees so that it is 180 degrees from
its locked position.
Take your hand off the shackle and pull it out.
Turn it back to the locked position.
Push the shackle into the lock and turn at least one of the
lock's dials.
Write down your new combination.
Keep this paper in a safe place for future reference.
the lock is currently set to 000. To set your own combination and with the lock in the 000 position, open the case and on the inside of the lock mechanism you will see a red tab. slide this tab to the left and then move the digits on the front to your desired code. ie 123. then move the red tab back to lock in this new setting as your own personal combination. close the case and then move the digits away from our setting of 123 and this locks the case. only if the digitrs are 123 in this example will the lock now open.
