My AEG Lavamat Turbo 12710 Update - Dryer program selected - pump starts and then fan starts but no heat from heaters. Heaters testing ok at 56 ohms with no earth faults. Both Heater thermostats closed ready to operate. Sensor at front of machine in duct above door is open circuit but dont know if this is a symptom. Any ideas? Does anyone have a circuit diagram.
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
