SOURCE: Suzuki banleno 2005 need parts details
I would contact the bureau of automotive repair and file a complaint.
SOURCE: cabin filter element location
Filter is located behind the glove box. All you need is a screwdriver to replace.
1. Open the glove box and empty to take the weight off the box.
2. On the right side there is a plastic hinge like device held on by one Phillips head screw. If you have trouble removing with a Phillips screwdriver you can remove with a narrow flat head screwdriver. Remove the screw and slide hinge off the mount.
3. To drop the glove box press the sides slightly inwards while 'forcing' it open beyond it's normal stopping point. Careful as when it releases it will fall wide open and may even fall from its hinged area. Set it aside.
4. Behind the glove box there is probably some fiberous material inserted to prevent noise like squeaking when it rubs. It is sticky on one side to hold it in place. Just remove and place out of the way.
5. Behind the fiberous material there'll be a cover which kinda looks like a grille. Mine was white and it is in the center of the opening. Remove it by releasing the clips at the left or right. It comes right out.
6. When the cover comes off slide the filter out and replace it. The filter lays flat and just slides in and out easily. However, if it has been some time since you replaced be prepared for a lot of debris on top of the filter such as leaves, grass or other general type of debris that has been sucked into the filter. It also may be the source of any bad odors that you smell through the air conditioning system.
7. Reverse the process. Replace the cover and push the glove box lid back into place. When you replace the glove box be careful to make sure the hinge you initiallly removed the screw from is not left behind the glove box or you will have to remove again to get it out. Replace the screw and do not over tighten as it screws into plastic and then your done.
SOURCE: the engine- gt tdi - needs cranking for 2-5 secs to
It is not air or fuel supply. Do not try clearing the fuel lines.
You have a faulty residual fuel sensor. This is part of the warm start system. A small amount of fuel is held under pressure so as there is pressure in the system to start the car. Pressure varies due to heat. Yours is failing under heat. When cold it starts just fine.
Go to the library ask for the Robert Bentley (authors) service manual for your model and yr. If they don't have it they will get it from another branch (free). Look under fuel system and you will see all the details on the system.
It is not hard to check, remove and replace.
SOURCE: toyota 2002 xl engine light
Take it to Auto Zone for a free engine code reading. They'll be able to tell you exactly why it's on. Sometimes it's even because your fuel cap isn't on all the way.
If it is a Generator... Get the measurements and contact us. We should be able to match it for you.
www.generatorguru.com
