EF0 then EF3 ode, emptied filter, hose, tilted machine but no water comes out. When I turn power back on I can hear pump running and when I turn dial the code reappears.
SOURCE: wont drain
The Hmming could say the pump works just fine. But I'm sure the not draining is caused a Valve in the Pump being dis-aligned or something. Try to contact service repair guys, or call and describe the fault :)
SOURCE: I have a Lavamat L14510
As you say that the filter WAS blocked but you do not say if you were able to check the drain motor/pump itself, I would advise checking the operation of that first by following the notes through to those in bold italics ;-0)
(This is pre-typed as I cannot type that fast!)
Following are my complete and generic guidance notes for checking both the drain motor filter and the drain motor:-
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
