The riding lawn mower I have is a Husqvarna 204LS riding lawn mower. I am needing to know how to keep it running, it dies after starting it, I charge up the battery then start it it then it will run but, after a while it will run down as well as draining the whole battery empty then I have to recharge the batery again don't know why it does that can some one help me please and thank you..?
SOURCE: I have a murray 22 inch lawn mower with a 4.0 hp briggs and
Change your air filter, spark plug, fuel filter, and oil. Then make sure the gas is fresh. Gas starts going bad after a month. Spray carb cleaner in hole underneith the fuel filter. Oh yea dont put more than 20oz of oil in it.
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
SOURCE: Lawn mower will not start and run
Sounds like a clogged carb or a cracked primer bulb. I would install a carb rebuild kit and new primer bulb if your mower uses one.
SOURCE: I can crank my murray gas lawn mower 6.5 quantum
Sounds like you will need to clean your carburetor.
Sometimes you can get by with priming it a few times, and letting it
run a few times like that and it will flush the gunk out of the jets,
but most of the time you will need to rebuild the carburetor.
If the mower is over a couple years old, then I also recommend that you
buy and install a new carburetor repair kit, because the diaphragm will
get hard and that will cause it to be hard to crank.
When you clean your carburetor and remove the jet screws, count the
number of turns it takes to seat the jets from their original position.
That way when you go to put the jets back in, you know how many turns
they were in/out.
Please rate me, Thanks
Good Luck, I hope this helped
SOURCE: My lawn mower starts, runs for about 5 seconds and
The engine is starving for fuel, that is why it will keep running while you force the fuel to the engine with the primer button. At this point, the carb will have to be removed,disassembled and cleaned. I'm sure you will find blockage and dirt in the carb and also in the small orifices for air and fuel flow.
