Mantis tiller 2 cycle seemed as if it was running out of gas
Pulled the carb and blew it out/ runs much longer but still dies. could the float need adjusting? it has fresh gas. new plug. it runs long enough to adjust the HS jet. did that. Any suggestions? Steve
Re: mantis tiller 2 cycle seemed as if it was running out...
Check fuel filter and lines, if thay are good I would get a carb kit and set the adjustment screws at 1 turn out from lightley seated to start. Don't lean high speed screw too much.
You might check muffler & cylinder port for carbon first.
Hi anon, if it's starting your 2/3rds of the way there. You have fuel and spark. Try and clean the air filter first and if that fails to keep it running then check that the choke isn't staying out. If all thats ok then it may be the carb gaskets.
The carb jets are clogged, it will have to be removed and soaked in carb cleaner. Sometimes that will not work either, and the carb will have to be replaced. Reason is, some of the carb passages are as fine as a human hair, so it's hard to get gunk and bad/dried gas deposits out.
You could try running something called Sea Foam (mixed in the gas)from Walmart through the tiller for a while, that MAY help somewhat.
Sounds like it's flooding either from over choking or the inlet needle in the carb is leaking. Have you removed the plug and blown out the cylinder and plug with air and then tried to restart? Be careful not to keep cranking with the choke pulled out. When it 'hits' ONE time, move the choke halfway in and crank again
Your quickest fix for this problem is to simply replace the carburetor, a Zama K54A. Do it all the time. After that, if you can find a 2 cycle oil, Opti-2, it's the best you can use and it's a one mix for all your 2 cycle equipment (blowers, trimmers, chainsaws, etc.) It's the only 2 cycle I sell in my shop.
This could be one of several problems... • Last year's fuel. Get some fresh gas. • Every 2-stroke needs a new spark plug each year... you know what that means. • Clogged carb jets due to storing the tiller over the winter with fuel in the system. Never, ever do that. Now you'll need to pull the carb apart and clean it. Most of the orifices are so tiny you can't see them. Good luck. • Engine is so old the crankshaft seals have hardened with age. This is one reason no 2-stroke lasts longer than about 8 years. If the seals are shot, then it will cost more to fix than a new one costs. Time to toss it.
