This is a slow drip, drip that you hear when the washer is not performing a wash. It is coming from the drain pipe that is connected to a vertical wall drain pipe. No other water is leaking any where else. The noise is really loud since it is echoing in the PVC pipe in the wall. How to stop and is this a sign of some other repair needed?
If not during a wash it is standing water.
Remove tube and check for cracks. If so, replace. Does/did the washer "walk"? May have rubbed the discharge tube and caused the leak.
Is the down pipe in a cold external wall? May be condensation from humid air hitting cold.
If the sound is the problem, attach a string to the drain pipe so water drips directly to side of vertical pipe.
SOURCE: Kenmore elite washer problem
you can use a shop wet vac on the drain hose to **** the rest of the water out then you can remove the hoses to check to see if anything is suct in hoses or pump-,mike
SOURCE: Kenmore Elite HE 5t front load washer - F20 signal will not drain
http://www.fixya.com/support/r3608632-f20_error_code
