Problem with AEG Washing Machines Aeg l14710. Hi can you help me made a decision on my six years old heavily used machine? each program can be set to show the program time but the machine will not start. the door locks. and the machine also has made a noise while draining for some time.
Hello!
Probably you have foreign stuff in the drain pump or the pump worn out. Unplug the machine and unscrew the pump cap, watch for water pouring out, prepare something to catch in the water, then inspect for coins, knobs, ... . Check if the pump wheel rotates freely. screw back the cap and try to start a new wash program
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
SOURCE: The door lock flashes constantly - Indesit WIA101
Switch on machine and start its program. While it is running then turn program selector control to TOP position. After a few seconds ALL lights should flash and machine should stop. It ought now to have been reset to normal.
SOURCE: Washing machine door lock problem
Just try to check the door latch device. Be sure that the latch is not bound or sticking in any way .This problem with a lot of machines and it almost always was the door lock latch assembly. It has a switch inside it that pauses or stops the cycle if the door is not closed properly, when this switch malfunctions then it will pause or stop the cycle repeatedly; just from the small movement of the wash cycle. The door will actually be shut all the way and the lock may be on. You must replaced this switch so it works normal again..
Just click for the spare parts site link;
http://www.repairclinic.com/SmartSearch/SmartSearch.aspx
Hope it may help you;
Regards,
VOTIT
SOURCE: AEG LAVAMAT 74620 - Washing Machine CE error code
Replace Water distributor (Dispenser Drawer) then will be Ok
Rafiq
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
