Generator will not stay running. maybe needs carb adjustment but need manual
SOURCE: My porter cable generator 3000 wt will not stay running once star
If this generator has been stored for any length of time with fuel in the carb you probably have a plugged main jet in the carb. As joboo1 says there are a few other things that could cause this behavior, but most often I see dirty carbs, water in the fuel, and plugged/dirty air filters. Get a flashlight and look into the fuel tank thru the filler hole, if you see anything floating in there you've got water in the fuel. Look at the ari cleaner, oil and fuel on the element indicate a dirty carb. Of course check the oil level. Lastly, take the bowl off the bottom of the carb (shut off the fuel valve first), if you see debris in there the carb needs a good cleaning.
Regards,
Carl
SOURCE: what carb does the powermate 6875 use?
check this web site http://www.powermate.com/productmanuals.php?cat_id=3 you can down load the manual and parts list for your gen.
SOURCE: Need Owners Manual
The best place to obtain manuals at a discount price is - repairmanual.com
Hope this works for you.
SOURCE: Is there anywhere I can download the pdf file -
http://pdfcatch.net/ebook/coleman+generator/
SOURCE: I have a Kohler RV
it sounds like that, I would look at the needle valve to make sure opening. What I would do is remove the bowl and let gas flow thru it, then push up on the float valve and release to see if you get another stream of gas. What you can try also because I think there is gum(from stale gas) is running with the choke partially on till it starts to flood out and the open choke and see if continues to run. I don't know how extensive you mean when you say "cleaned" the carb but you might have to again with a good carb cleaner or find a soak for it.
