Lavamat 75620 typ : B46 A Eo3d 12 A pnc 914 001 295 00 50HZ 2150W
Do google search for "user manual AEG oko lavamat 75620" on page 2 about 4th down you will see a pdf manual for your model ( it's the "update" model but they are virtually identical to use ) don't download straight away it's foreign but don't despair click the option Translate this page and you'll then download an english version of the standard commonly experienced when Nigerian or Ugandan ex govt ministers let you know, via email, of an opportunity to help them smuggle millions out of their respective countries. never-the-less you will be able to run your machine from it.
SOURCE: AEG OKO Lavamat Update washing machine LAVALOGIC 1600
This error code (C3) means your water sensor has detected a leak. it will stop when the sensor is dry.
Try getting the water out of the trap door and letting the machine dry.
I would also unplug it for secirity reasons.
Basically your water pump is getting tired or the sensor is dirty. Try cleaning the sensor or else you may have to change the pump.
Good Luck!!
