The washing machine won't rinse or spin, it will aggitate but stops at each rinse/spin cycle of the timer. It doesn't matter if it's on the regular wash cycle or delecate cycle, it stops at the rinse/spin.
repeats wash only does not rinse or spinrepeats wash only does not rinse or spin
AnonymousMar 19, 2014
Machine seems to rinse more than once in a cycle and isn't spinning properlyMachine seems to rinse more than once in a cycle and isn't spinning properly
You can't post conmments that contain an email address.
Best guess is a timer contact problem, usually caused by advancing the timer by hand without pushing the dial in to stop the machine first.This causes burnt contacts.
probably you've got something blocking the water pump from doing its job properly so check that the water pump is free running emptying all the water if not then there is a blockage in the pump normally ist a button, paper clip or other debris out of a trouser pocket eric
see the next steps and use the common sense: God bless you When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:It's
the timer, if your washing machine fills with water and begins
agitating, but the timer never advances--or if the washer is in a spin
cycle and the timer won't advance. Then you need to replace the timer. It
may be a cold-water supply problem, if the washing machine fills with
water, agitates, drains, and spins, but then doesn't fill with rinse
water. See There's no cold water.
without knowing more details, and considering it's age , my guess is that you have a disconnection (or a loose wire) to the solenoids under the tub. these solenoids activate the clutch system that pulls it into agitate and spin modes. it might be the solenoids, but rarely do both go out at the same time. it might be the timer contacts or connections behind the control panel. or, it might be the timer its self.
try unplugging the unit and check all the connections.
hope this helps jay
If the timer gets to the rinse cycle and stops, Check the lid switch for continuity. If no continuity replace the lid switch. If the timer continues through rinse and spin without doing either, replace the timer.
