Good Afternoon Frankie, thank you for your inquiry!
Based off what you have described your Frigidaire dryer is not starting and will only beep three times. This could be a possible issue with your control panel or sensor. I would recommend performing a reset on your washer and you can do that by unplugging the power cord for at least ten minutes. You may also want to check your household circuit and assure that the breaker did not flip or that the circuit has not shorted. If that all appears to be in proper working order then I would suggest consulting with a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
