What is your model number is then we can get started then
hi chalie,the numbers shown when the door is opened are:-LW 1050, typ 47BMCCB10A, PMC 91400242400, S-NO 32038583. thanks
is any one is the model number if so wach one it is then
sorry but your reply makes no sense
i understand now, pmc 914002424000
I will get back I am on my phone right now but I will get back when I can
still waiting
I am sorry I can not help you with your problem right now okay
I will try to help you But not right now okay
SOURCE: does not spin when inserting 5.5kg clothes ,only when decreases weight
I'm not a technician, but I own a AEG Lavamat. As far as the owner manual says, this washing machine doesn't allow more than 5 kg.
SOURCE: Lavamat 16820
The reason the machine is coming up with E20 when drying.
is that there is a blockage of fluff in the dryer air duct on the right hand side of the machine just below the fan unit.
the air that goes through this duct is heated and returns back to the tub to dry the clothes. because there is a blockage in this duct the fan pushes air up the pressure switch tubes and fools the machine in to thinking that there is too much water in the drum,
too remove this blockage you have to disconnect the power supply, remove the lid and remove the back panel, 4 screws at the bottom + 4 up top under the lid.
plull the water pipe with the valve out of the way and pull back panel away.
you should now see the dryer condensor unit blocked up with fluff. remove this unit and clean with bottle brush.
replace and make sure hoses are done up tight. replace back panel and lid, try again on drying and things should be alot better, drying should be alot quicker as well.
SOURCE: AEG Lavamat 16820: Strange noise coming the machine
Ok, the motor windings are bad. the A.C. hum is a warning that the motor will sound when the windings are separated or shorting. its unable to hold a balanced current.the motor will actually stop soon if it isn't repaired.
SOURCE: AEG Lavamat 64810. No error
The fault has been described well by you and it is confirmed that the motor is not running. Now eventhough you have mentioned a clean chit to the control panel I would like you to take a voltage check on the motor when it is in wash cycle.
If the power comes on and there is no motor action then it is confirmed that the motor is fauly. But if there is no output of the voltage to the motor from the controller, the it is possible that the controller is faulty.
If motor is humming and is of single phase type, check the capacitor and replace if motor is humming and not running.
.I am sure you can sort this out having come this far.
Hope my tip helps
if you cant help, can you find someone who can please.
Then Call 570-379-0993 for someone to come out to fix your problem then got that yes or no
can you refund my money, as you have been unable to sort out the problem.
no i can not!!!!!!!!!!!!!!!
the phone number 570-379-0993 is for chas&son,s appliance repair if you want your unit to be fixed yes or no??????????
