? 4:22
https://www.youtube.com/watch?v=R65JJYwSH50
Jun 28, 2010 - Uploaded by R/C 101
Does your RC helicopter spin out of control in the air or ... thing that the video says but there nothing wrong about it the remote is fine but the propeller .... i have a brookstone RC stunt copter that i have not used in a few months. i .... however when I come to fly it, it makes a sound but the wings aren't working.
where can I buy new gears and pinions for my mini rc helicopter?. Read more Show.... The two pins on the charger port aren't working they won't charge ..... The charging light is off meaning the battery is charged. Any ideas? ..... So, the motor spins the correct way but there is no gear to transfer the power to the rotors 'A'.Missing: silver ‎bullet
If your Brookstone Stunt Copter RC helicopter is not getting enough power after being charged, there could be a few different issues that could be causing this. Here are a few things you can try: Make sure the battery is fully charged: It's possible that the battery was not charged for a long enough period of time, so make sure the battery is fully charged before trying to fly the helicopter again. Check the battery connections: Make sure the battery is properly connected to the helicopter and that the connections are clean and free of corrosion.
Try a different battery: If the issue persists, try using a different battery to see if that resolves the problem. Check the transmitter: Make sure the transmitter is properly charged and functioning. Check the helicopter's Motor: Check the helicopter's motor to ensure it is working properly. If the motor is not working, the helicopter will not have enough power to fly.
Check the helicopter's circuit: Check the helicopter's circuit, if any of the circuits is damaged, it may cause the helicopter to lose power.
If none of these steps resolve the issue, it is possible that the helicopter may be defective and require repair or replacement. In that case, contact Brookstone customer support for further assistance.
I presume you have lights & sound on the controller when you turn it on - fourteen quick beeps and then a different toned fifteenth beep. The screen lights (blue). Insert the battery (lettering facing up toward the helo fuselage unitl it's seated all the way - an LED inside the fuselage, visible from behind, quick flashes and then begins a slower blinking.
Once the helo battery is inserted, turn on the controller, which starts the aforementioned beeping. On the last controller beep the helo's LED will stay lighted, indicating the helo & controller are synched.
I had a problem making sure the battery was inserted all the way into the helicopter. You'll know it's inserted properly when the LED inside the helo flashes.
Hi, Mostly all the micro copters problem are the battery and the the pinion gear that's been worn out. Check both of these part. Battery should at least gives out 350 mili amp. and the gear should touch the propeller shaft gear at the bottom of the copter.
Get a lithium ion battery for more power and longetivity.
try contacting the company. if the car wheels are broke or dangeling you would need new wheels. if the wheels arent the problem it could b the turning starvos
