Heating & Cooling Logo
ryan Posted on Dec 19, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I changed the thermo coupler and the pilot light does stay lit but the burners won't light
Anonymous
Level 2:
New Friend:
  • Expert 72 Answers
  • Posted on Dec 20, 2012
Anonymous
Expert
Level 2:
New Friend:
Answers
72
Questions
0
Helped
64434
Points
103
If you are referring to a gas fireplace:
  • Make sure the pilot knob is turned from "pilot" to "ON" or it will never run.
  • If the pilot knob is "ON", and the pilot is lit, but the burner won't light, it could be a bad Thermopile. The thermopile is the other safety mechanism in the pilot assembly that controls the burner.
5 Related Answers
Paul Carew
  • 3807 Answers
  • Posted on Feb 08, 2010
SOURCE: my pilot light wont stay lit
Hi try cleaning the pilot light out make sure the thermo couple is in the flame,check where the tcouple goes in to the valve nothing stuck in there try this it could be the valve not working
Anonymous
  • Posted on Nov 11, 2010
SOURCE: Pilot works, will not stay lit
Check your tip switch by putting a jumper wire between the two switch connections. If your burner lights replace the tip switch.
A Miller
  • 8404 Answers
  • Posted on Jan 04, 2010
SOURCE: i have a older Miller furnace(1989)the pilot will stay lit
Replace the thermocouple.
Try this, do you have a butaine stick lighter? Try to heat the thermocouple with it ... see if you can get the main burner to come on. If not - definitely, replace the thermocouple.
Thanks for your question.
cadesertmax
Frank Schultz
  • 274 Answers
  • Posted on Jan 11, 2010
SOURCE: Have Endless Summer patio heater. I got the burner
It could be the thermocouple, but you have to take the head apart to replace it. If you got the main burner to fire, then the thermocouple is probably ok. Try changing the regulator, easy to do and not to expensive. If that doesn't work, try taking the head apart and cleaning the pilot and main burner orifices, do both while you are in there. If you are not comfortable doing this, hire someone.
Anonymous
  • 221 Answers
  • Posted on Jan 13, 2010
SOURCE: The pilot light will not stay lit, I was told
Hi, this heater doesn't have a thermocouple, it uses a pilot generator which is more reliable so I doubt you need to change it out. First thing to check is that you have a clean "sharp" blue pilot, you should be able to hear it quietly roar. If it is yellow and appears "soft", the pilot need to be cleaned. The easiest way is to use a straw or tubing of some sort to blow into the pilot, gently tapping the pilot assembly. That should clean it up and heat the pilot generator properly. Tighten the the screw terminals at the control valve to assure good electrical connections and last but not least turn off the thermostat until you get a standing pilot. Good luck and stay warm.
MY MAGIC CHEF, CONCEPT SERIES, W/MAGIC CONTROL CENTER DOESN'T LIGHT.
I have a Magic Chief Concept Series oven - Replaced the Thermo-coupler and the control switch. I now have a pilot light but the thermo-coupler doesn't get hot enough to light the burner, But if I take a lighter and put it on the thermo-coupler it will but when I take if off it shuts off after a few seconds. Could you please give me Ideas of what could be wrong
The pilot won't stay lit on gas hot water tank.
Make sure thermocouple tip is seated inside the burner flame.
Make sure thermocouple is not overtightened. Finger-tight + 1/4 turn.
If the pilot lights, then ECO energy cut off is not tripped, but gas control valve might be bad.
Check color of pilot flame: it should be strong and clear blue.
If pilot flame is weak, or color of flame is yellow-orange: Clean pilot orifice and burner and combustion parts on yearly basis.
Clean air intake screen if applicable.
Increase air supply to water heater. Open a window and see what happens.
Check for adequate draft going up chimney using match under vent hood to see if smoke drafts immediately upwards.
Bleed air out of gas line.
Check gas pressure.
Open following links for troubleshoot resources:
http://waterheatertimer.org/pdf/Pilot-light-will-not-stay-lit.pdf
http://waterheatertimer.org/pdf/Pilot-outage-troubleshooting.pdf
http://waterheatertimer.org/pdf/Vent-spillage-test-atmospheric-gas-water-heater.pdf
http://waterheatertimer.org/How-to-install-gas-water-heater.html#troubleshoot
Pilot light will not stay lit. changed thermo couple 3 different times but stil cannot keep it lit.
the gas regulator is your problem is the thermo coupler was changed so many times
I have universal 350,000 propane heater. Fan runs, but switch will not turn on to allow propane to burner.
The thermo coupler is at fault. If pilot won't stay lit thermo coupler keeps gas off. So, Unless it is a bbQ , make sure the pilot is on or the thermocoupler stays hot while the gas is on.
10helpful
No hot water, pilot light lights but no burner ignition
Thermo coupler may be defective. it controls the main gas valve by closing main if pilot is out. make sure thermo coupler bulb is positioned over and near tip of pilot flame, but not in the flame. Thermo couplers are inexpensive and easy to change out.
Thermo coupler on all the time, push in button, shuts off gas
Bad Safety valve. (valve w/red button). Thermocouple keeps the magnet open to keep pilot and so gas can flow to burner. Make sure pilot is clean and strong and hitting thermocouple. If it doesnt stay lit replace Safety Valve.
Top Heating & Cooling Experts
Paul Carew
john h
