First pilot wouldnt stay lit changed thermocouple made hood for pilot burner to get pilot to burn close to thermocouple pilot stays lit turn on burner wich burn for a while then pilot and burner both go out also changed out pressure regulator with rated for 200000 btu using a 20 pound cylinder for fuel wich is new
SOURCE: MH 18 B wont stay lit
sounds like you have a limit safety issue, the unit is over heating and kicking out on high limit, or the limit is weak, either way you should look into replacing the limit, hope that helps
SOURCE: Stays lit for 25 minutes and shuts off
How large and sealed of an area are you using it in? I ask because those units have a low oxygen sensor which will shut it down if there is not enough oxygen in the space.(kinda prevents that pesky suffocation thing). Otherwise if using it in larger cold spaces, the issue is can be from the smaller tanks. As mentioned above, a larger tank can solve this, because these units have a fairly good input rate, which will cause the smaller tanks to freeze, and lower the propane temperature and evaporation rate, basically runs out of gas until the tank warms back up.
SOURCE: pilot will not stay on
replace your regulater,which almost cost as much a a new heater.I have own 4 or 5 and finally got a good one,I have in the past cleaned out the regulator that was plugged with oil from the propane,they put oil in the propane for leak detection,I hope this helps you
Testimonial: "Thank You. perhaps it is not adjusted properly. I so appreciate the quick response..Good Job!!!"
SOURCE: Is it o k to bend the thermocouple tip. The only
Bending it will ruin it. You need to find out why the pilot flame is not as strong as it should be.
It is usually caused by bugs or spiders having gotten into the small air mix jet of the pilot assembly and died or built a web or, there is some dirt from the fuel that is partially clogging the fuel tube leading up to the pilot assembly, or plugging the orifice.
Testimonial: "worked perfectly"
