Lionel 11000 Holiday Tradition Express Train Set Logo
mary ann edwards Posted on Dec 03, 2012
Holiday Tradition Express, engine tender not working. Contacted Lionel Trains, they have no replacement parts or service available.
ltd1217
Level 1:
  • Contributor 40 Answers
  • Posted on Dec 04, 2013
ltd1217
Contributor
Level 1:
Answers
40
Questions
0
Helped
13620
Points
46
Best bet is to search the internet for Lionel replacement parts. Try to include as much information in your search.
2 Related Answers
Anonymous
  • Posted on Dec 27, 2009
SOURCE: i bought the set last year of holiday lionel
If all cars are not properly on the track, the engine does not have enough power to pull the cars. Try with engine and coal car only to zero in on cause.
Anonymous
  • 4 Answers
  • Posted on Nov 29, 2011
SOURCE: Remote is not working for my Lionel Holiday Tradition Express Train with new batteries. Any suggestions?
I rewired my train this weekend..it now works on my outdoor setup....I found that the circuit board inside the engine had a blown capacitor and the power transitor was fried. I by passed the engine board found that it only would run backwards....went into the tender and taped into the power from tack bypassing the rectifer... By the way the engine does not start up when one uses the remote...there is a 20 second delay before starting
Lionel o guage polar express set transformer has a bell button but don,t work no sound
IfIam correct, the basic Polar Express came with just a whistle. There is an optional coal tender that has a better sound system in it...Whistle bell and steam sound also try reversing the power wires at the transformer or track
Will not go forward, but will go reverse
Diagnostic: Poor connection/conduction between carbon brushes and rails.
Solution: Clean carbon brushes and metal rails with solvent. If problem persists you must need to expand the inner carbon brushes' coil spring from the second car.
1helpful
Have a lionel holiday tradition express. Lights are on, but train won't sing or go forward. Changed batteries and nothing.
Have you let the loco charge first? The instructions are a bit vague but the loco needs to charge before it runs. Not easily understood from the instructions and many have spent some frustrating minutes wondering why their train wouldn't move.
Our Lionel Holiday Tradition Express Set 7-11102 will not move even though all of the other functions work properly
Did you check the reverse switch? Be sure that it is turned ON. If your locomotive still will not run, check that there are no fibers wrapped around the wheel axles or any exposed gears. If none of these fix the problem you will need to take your locomotive and tender to a Lionel Service Station.
Dec 21, 2010 • Toys
1helpful
2answers
On my Lionel Holiday Tradition Express the handheld remote works yet with the train will not respond. All connections have been cleaned and that is not the problem. I did notice that the wheels on the...
the train does not run in daylight.....when one places the remote over the engine protecting the senor from sun the engine will start 10seconds after the sounds...I was very disappointed that it would not run in daylight. I'm looking for a method to rewire the system to work in daylight....maybe bypassing the control card.
2answers
I bought the set last year of holiday lionel trains g replaced batteries, have light on remote and noise from engine but no movement? any ideas
1helpful
2answers
The train is not responding to the remote.
I had a similar problem with my 11000 Holiday Tradition Express. I cleaned the track with an eraser (pencil-type) and then used a soft cloth to clean any possible residue. After doing this twice, my train is now running.
Top Lionel Crafts & Hobbies Experts
xxxxxx xxx
ADMIN Andrew
ADMIN Andrew
Carolyn Rogers
Are you a Lionel Craft and Hobby Expert? Answer questions, earn points and help others
