It is a 2003 model, this is the first problem. Water drips from between the plastic drum surround & a moulded concrete part.
it happens when the water level in the drum is at Max.
Does anyone know if this is a common fault & if so is it possible to fix?
The model is FLA1002W
SOURCE: zanussi washer dryer model-WJD 1257 W
Not sure about the drawer leak, but have some ideas about the refusal to empty. Have a look at the section in your instruction manual (copy here: http://www.serviceforce.co.uk/pdfs/U23119.pdf) about cleaning the filter (pages 20-21). Check the filter isn't completely choked. Expect quite a lot of water to come out when you remove the filter. While you've got the filter out, have a look in the hole it came out of. At the back of the cavity you should see the pump impeller (looks like a four-bladed fan). With the power off(!) give this a spin with your fingertip. It should be free to turn (although it's normal for the movement to be very notchy). If it won't turn, see if you can find anything jammed up in it. Keep looking in the same cavity. Somewhere about halfway back, usually on the top wall, you should find a large hole (this is how the dirty water gets into the pump). Slip your finger as far into this as you can without getting it stuck, and just check nothing is blocking it (20p coins are favourite problems here). If you've still drawn a blank, then without replacing the filter turn the power back on, set the machine going on a spin cycle, and look to see if the pump impeller is whizzing round. Don't be tempted to touch it, as it can rap your knuckles very hard. If it won't turn, you probably need a new pump. Replacing a pump is a pretty low-stress affair. It's more or less obvious where everything is meant to go. You can get a new pump from one of the internet parts suppliers for about £35 (it's worth shopping around, as prices very wildly). Hope this helps a bit. A.
SOURCE: zanussi electrolux washing machine zwf1431w
Error E20 means the machine has failed to pump out. 1st check the filter at the bottom right hand side there may still be water inside if so pull the grey tab to the left of the filter there should be a thin hose extend it put it into a shallow dish and pull the cap off to let the water drain this may be a slow process. When the filters out look into the hole with a torch to see if any obstructions in the pump impeller this looks like a cross. If the filters and pump are clear it may be the pump has failed.
SOURCE: washing machine keeps stopping mid wash and coming
Hello
ALARM CODES
E11 Problems with water fill in wash phase E10 Cycle PAUSED 8.2
E12 Problems with water fill in drying E10 Cycle PAUSED 8.3
E21 Problems with water drain in wash phase E20 Cycle PAUSED 8.4
E22 Problems with water drain during drying or drying
condenser blocked E20 Heating phase skipped 8.5
E31 Analogic (electronic) pressure switch circuit faulty --- Cycle blocked
with door closed 8.6
E32 Incorrect calibration of analogic (electronic) pressure
switch --- Cycle PAUSED 8.7
E33
Incongruency between level of analogic (electronic)
pressure switch and level of anti-boiling pressure
switch 1
--- Cycle blocked
with door closed 8.8
E34 Incongruency between level of electronic pressure
switch and level of anti-boiling pressure switch 2 --- Cycle blocked
with door closed 8.9
E35 Water level too high --- Cycle blocked with door
closed and water drain 8.10
E36 "Sensing" circuit of anti-boiling pressure switch 1 faulty --- Cycle blocked
with door closed 8.11
E37 "Sensing" circuit of anti-boiling pressure switch 2 faulty --- Cycle blocked
E38 Pressure chamber blocked --- Heating phase skipped 8.12
E41 Door open E40 Cycle PAUSED 8.13-14
E42 Problems with door closure E40 Cycle PAUSED 8.15-16
E43 TRIAC which powers the door interlock faulty E40 Cycle PAUSED 8.17-18
E44 "Sensing" circuit of door delay interlock faulty --- Cycle blocked 8.19
E45 "Sensing" circuit of door delay interlock triac faulty --- Cycle blocked
with door closed 8.19
E51 TRIAC which powers the motor short-circuited --- Cycle blocked with door
closed (after 5 attempts) 8.20
E52 No signal from tachometric generator --- Cycle blocked with door
closed (after 5 attempts) 8.21-22
E53 "Sensing" circuit of motor TRIAC faulty --- Cycle blocked
with door closed 8.23
E54 Relays (motor) contacts faulty --- Cycle blocked with door
closed (after 5 attempts) 8.23
E61 Insufficient heating during washing --- Heating phase skipped 8.24
E62 Overheating during washing --- Drain, end of cycle 8.25
E63 Insufficient heating during drying Heating phase skipped 8.26
E64 Overheating during drying --- Heating phase skipped 8.27
E66 Power relay to heating element faulty --- Drain, end of cycle 8.28
E71 NTC wash sensor faulty --- Heating phase skipped 8.29
E72 NTC sensor on drying condenser faulty --- Heating phase skipped 8.30
E73 NTC sensor on drying duct faulty --- Heating phase skipped 8.31
E84 "Sensing" circuit on circulation pump triac faulty --- Drain, end of cycle
(door open) 8.32
E85 Circulation pump faulty --- Drain, end of cycle
(door open) 8.33
E91 Communications error between main PCB and user
interface --- --- 8.34
E93 Configuration error E90 Cycle blocked 8.34
E94 Incorrect configuration of washing cycle E90 Cycle blocked 8.34
EF1 Drain filter blocked LED-EF0 --- 8.35
EF2 Excessive detergent LED-EF0 --- 8.35
Regards David Marsh
SOURCE: Zanussi ZWF14070 - concrete 'damper'
Moulded plastic 'spigots' still form part of the drum housing, but no concrete block is now fitted to the rear.
