My watch has 4 buttons (2 on the left, 2 on the right) plus the "Indiglo" button. Use the "Mode" button (lower left) to move between the time and the stopwatch. When seeing the stopwatch, hold the "Mode" button. This will get you to the alarm setting mode. Press the "Mode" button again to switch to the time setting mode. Use the "Start/Stop" button (upper right) to move from seconds > minutes > hour > date > day of week. Use the "Spl/Reset" button (lower right) to change the numbers
SOURCE: digital umbro watch purchased 2001.How to change
Press mode continuously for about 2-3 seconds then release
Press mode again so that the seconds are flashing
Press ADJ + ST/STP at the same time
Adjust what you need to adjust and move between minutes and seconds by repeating the ADJ + ST/STP
Thanks!!
SOURCE: Setting Timex watch
Since you have changed to the newest program I cannot get in the watch program I was using to set the watch. Please help.
SOURCE: I cant set the correct day on my digital watch ,The watch has CG onit and is WR 100FT
press mode 3 times to get to time set. then press reset to choose (hour, minute, seconds, day, month, date) and press start to change them. press mode again when finished.
SOURCE: I have a WR165 Armitron watch and I cant change the time
You can get a of instructions from the Amitron site
"/www.armitron.com/watch_instructions.asp"
Scroll through the instructions until you find a watch that looks like yours and download the instructions.
