Model #20882 (990) top loader washer. when it got to the rinse cycle it wouldn't agitate or spin. it took a while to drain but it did eventually drain. made a sound almost like it was on tilt but it wasn't. now we can't get the back off to see if it could be a belt that is at fault.
SOURCE: Kenmore 80 series 110 washer making loud noise during final spin
Make sure all springs are still in their place tilt the machine back and look under it and you can see them. 2nd all legs must be level as well as the floor.
SOURCE: Kenmore 90 series top load washer: won't agitate or spin
Sorry to give you bad news but this sounds too much like the transmission is shot. It's a bit of work to change and probably some luck to find one at a reasonable price, so my advice is to ditch this machine and get another. :(
Joe
SOURCE: Kenmore 70 series washer making humming sound and won't agitate
The following advice is for replacing the “Agitator Dogs” on Kenmore and Whirlpool TOP LOADER style washing machines. This simple repair can save you a fortune in repair costs as the replacement parts are very inexpensive at a cost of less than $10. The replacement kit part number is 80040. You can order on line at various appliance parts websites, or use this part number and go to your nearest appliance parts retailer.
What are “Agitator Dogs”? These are small plastic pieces (usually 4) that are located under the agitator center cap that grip the agitator and turn it during the wash cycle. They can (and do) wear out dependent upon the use of the washer. If you are in the habit of doing large load sizes frequently, or wash large items such blankets or afghans, this can wear the teeth off and reduce the life of the agitator dogs.
SYMPTOMS REQURING REPLACEMENT: The agitator fails to turn during the wash cycle, or will not turn with a heavy load. The timer will run normally through all cycles, and you will be able to hear the gearcase (transmission) engage and run. The washer will also drain normally. The only indication that something is wrong will be the agitator slipping or not turning at all. The result will be clothes that do not wash properly and will sit on the bottom of the wash tub.
To replace the Agitator Dogs, follow these steps:
1.Remove the agitator center cap by either pulling straight up or gently placing a flat blade screwdriver into a slot located in the cap.
2.If the agitator is equipped with an inner cap with a handle, remove this as well by pulling straight up.
3.Remove the center bolt of the agitator. You will have either a 7/16” hex bolt or a recessed square plastic nut. If you have the square recessed type, use a 3/8” to ½” ratchet adapter to remove.
4.Remove the agitator by grasping the bottom flange and carefully pulling straight up. Try to keep all the parts assembled while doing this, so do not pull too hard. This will make this repair much easier.
5.Place your hand over the top of the agitator and separate the upper portion of the agitator from the lower portion and turn the top half over in your hand. The agitator dog assembly will come out in your hand.
6.With the agitator dog assembly in your hand, lay the rest of the agitator aside. Pay careful attention to how the dogs are installed. Remove the worn dogs and reinstall new ones. It’s that simple.
7.With all the dogs replaced and the assembly still in your hand, place the upper part of the agitator over the top of it, upside down, ensuring the inner assembly tabs align correctly.
8.Now keep your hand over the agitator top to hold all the pieces together and turn the entire assembly over (upright position).
9.Carefully align and reinsert the upper portion of the agitator to the lower portion. Again, making sure the two pieces align correctly.
10.Place the entire agitator assembly back on the gearcase shaft and reinstall center nut. NOTE: DO NOT over tighten the nut, or the agitator will not spin correctly. Just make the nut snug. Reinstall center cap and inner cap (if equipped).
These instructions should give you the basics on how to perform this repair. Since there are various agitator types in use by Whirlpool and Kenmore, assembly can vary.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
SOURCE: my kenmore washer 80 series
I would gently suggest as a first step that you clean the drain motor/pump lint tray/filter. So many 'faults' are caused by blocked filters and many machines will not even go to rinse or spin or release the door lock if there is any water still left inside.
Here are my complete and generic guidance notes for checking both the drain motor filter and the drain motor ;-0)
If you are unsure where the filter is, it is often behind the front lower (kick) panel (or in some machines at the rear in an awkward position!). These panels are either held on by (plasic) screws or will just pull off. Most filters are held in by a round cover/knob. Sometimes the filter will not come out with the cover and you will have to persuade it to come out to play.
REMOVE POWER AND ENSURE YOU HAVE A WATER RECEPTACLE/RAGS TO SOAK UP THE WATER WHICH IS BOUND TO POUR OUT (alternatively use a wet vac as sensibly suggested by VinnyB1234!)
It's surprising what people have found in theirs! It is always worthwhile checking it on a regular basis.
Now- whilst the filter is removed it is normally possible to see the drain motor and ensure it is not jammed by a foreign object such as a needle or a toothpick. It should be able to be turned by hand/finger- the power IS OFF!
At this point it is also possible to test if the motor works. No clothes or water in the machine, select a spin cycle and put the power back on. You should be able to see the motor turning at some point, possibly straight away. Using something suitable like a glove see if it is easy to briefly slow the motor down. If it is easy then the motor is malfunctioning.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
SOURCE: I have a top loading Kenmore series 80 washer.
This is usually a door closed switch that is either a bad Lid switch It is number 11 on the diagram on this page http://www.searspartsdirect.com/partsdirect/part-model/Kenmore-Parts/Washer-Parts/Model-11024032301/0582/0153200/K0403014/00001?blt=06&prst=&shdMod=
Hope this answers all your questions
Please remember to Rate/vote for any solution that helps you out.
Leave a comment if you need more help.
Thanks for using Fixya.
