See your doctor
After Long Driving if you feel neck pain follow these tips:
1. Utilization of cold or ice packs: The virus lessens the aggravation, which thusly enables the strain to mend. This ice pack ought to be connected for 20 minutes interim in the initial 24 hours.
2. Use of warmth: Heat helps in carrying the supplement rich blood to the influenced region so as to animate a mending reaction. Sodden warmth just as the warmth from a hot shower or shower can be utilized. A few people may discover alleviation from applying warmth wraps, for example, thermacare.
https://www.lybrate.com/ludhiana/orthopedist
Swap sides with passenger and driver My 98 did that
SOURCE: head light 2005 altima
you have to remove the bulbs from inside of the hood in the engine compartment. in some cars you have to remove some "pins' and remove the entire headlight assembly.. You then remove the holder where the lightbulb is located and replace the bulb.
SOURCE: replacement of a head gasket on 2.5 liter nissan altima 2002
frajogag: First off, be aware that these bolts are "torque to yield" bolts (streach bolts). What this means is that instead of torqueing the head bolts to a specific torque specification, they are torqued down to a set spec and then tightened by rotating the bolts a certain angle, like 90 degrees. and all of them are turned the same amount.
This means that the shanks of the bolts must be checked to make sure they are not too thin (or the bolt has already stretched beyond limits and is prone to snap if used)
Here is how you check the bolts. Measure the bolt using a micrometer, at the base, or within the first 13mm from the end where it threads in. Then go to about 10mm before the threads end heading toward the top of the bolt. There should not be more than a 0.23mm (.0091 inch) or less difference or the bolt should be discarded.
Torque the bolts down to 98.1Nm ( 72.ft lb)
Looking at the head from the side, so you are looking at the full length from side to side, I will number the head bolts in this fashion.
#1 & 2 are directly in front of you and in the center of the cylinder head crossing it width wise.
#3&4 are to the left of #1&2, / #5&6 are to the right of #1&2
#7&8 are to the left of #3&4 / #9$10 are to the right of #5&6
Now, you have the sequence.
After the initial pull, back off all the bolts in the same sequence and then retorque them to 36 Nm ( 28 ft lb)
Using a torque angle wrench or having the ability to accurately judge turning angles. Rotate (clockwise) to a 75 degree angle. do this to all the bolts using the sequence I had provided.
Rotate the bolts (clockwise) 75 degrees again on all bolts in the same sequence. The proceedure is complete!
SOURCE: i have an 03 nissan altima engine makes loud clicking noise
1st check the the oil level and the vehicle's oil type.(owners manuel) 5w30-10w30
10w 30 is a thicker oil and could possibly be causing this.(Moves more freely through the engine heats the oil)
SOURCE: My 2005 Nissan Altima loss power while I was
the 2.5 altima's had a recall on that problem about 2-3 years ago. Go to edmunds or progressive find the recall letter and the dealer will fix it free. well here you go:
Recall ID # 07V527000 - ENGINE AND ENGINE COOLING
Recall Date:
NOV 14, 2007
Component:
Model Affected:
ALTIMA
Potential Units Affected:
653910
Recall Details
Recall Date:
NOV 14, 2007
Model Affected:
2005 NISSAN ALTIMA
Summary:
ON CERTAIN PASSENGER VEHICLES EQUIPPED WITH A 2.5L ENGINE, THE
CRANKSHAFT POSITION SENSOR CAN OVERHEAT CAUSING A BRIEF INTERRUPTION IN
THE SIGNAL OUTPUT FROM THE SENSOR.
Consequence: IF THE
INTERRUPTION IN THE SIGNAL FROM THE CRANKSHAFT POSITION SENSOR IS SO
BRIEF THAT THE ELECTRONIC CONTROL MODULE (ECM) LOGIC DOES NOT HAVE TIME
TO DIAGNOSE THE CONDITION, THE ENGINE MAY STOP RUNNING WITHOUT WARNING
WHILE THE VEHICLE IS DRIVEN AT A LOW SPEED INCREASING THE RISK OF A
CRASH.
Remedy: DEALERS WILL
REPROGRAM THE ECM FREE OF CHARGE. CERTAIN MY 2006 ALTIMAS WHICH HAVE
BEEN PREVIOUSLY REMEDIED UNDER RECALL CAMPAIGN 06V223 (NISSAN R0606)
ARE NOT INCLUDED IN THIS RECALL SINCE THE REPROGRAMMING FOR 06V223 ALSO
INCLUDED THIS REPROGRAMMING. THE RECALL BEGAN ON DECEMBER 31, 2007.
OWNERS MAY CONTACT NISSAN AT 1-800-647-7261.
653910
Notes:
NISSAN NORTH AMERICA, INC.
