My Sylvania - ground fault 15 amp breaker (32740) is tripping with minutes of reseting.
It is for 3 washrooms & hallway & is 30 years old .....does or can it loose its life span?
What is the cost...
A circuit breaker can go bad, but usually not in the way that you describe. That's not to say that it can't happen, but just not typical. GTE Sylvania breakers were once popular - I installed quite a few GTE / Sylvania electrical panels in homes in the late 80's. You may have trouble finding replacements; do not put an breaker that "fits" into the panel, unless the breaker is designed for use in the panel you have.
The first thing to do is determine the source of the problem. The breaker will trip, but not indicate if it was the result of a heavy electrical load or a ground fault condition. A 15 amp circuit breaker is designed to carry up to 12 amps continuously. The greater the load, the more quickly it will trip. it may carry a 14.5 amp load for several minutes to an hour before tripping, and a 20 amp load may be carried a second or two. GFI breakers are designed to carry 5 thousandths (.005) of an amp (or 5 milliamps) to ground, or the 12+ amps to neutral before they trip.
The way I would attack the problem is to install a new GFI outlet in front of the old wiring, by "inserting it" between the panel and the other plugs and lights, switches, etc on that circuit. The GFI outlet will provide the same GFI protection that the circuit breaker provided at a fraction of the cost.
Turn off the old GFI breaker, and remove it completely. Install a new, standard (non-GFI) single pole 15 amp circuit breaker in its place. Completely remove from the panel the cable that the old GFI breaker fed. Buy a new electrical outlet box (surface or flush mount as desired) that is large enough and deep enough for a GFI plug and 2 cables (if surface mount, use a 4" square deep box and appropriate cover - or if flush mounting use a deep plastic / fiber single gang box). It will be installed in a place close to the panel, but where the old cable will be able to reach inside. Bring the old cable removed from the panel into the new box. Run a new cable that has the same number and size wires from the panel into the new box, too. Connect the circuit neutral and circuit ground to the neutral and ground bars in the panel (they are probably the same bar) and the hot wire to the circuit breaker. make sure that the circuit breaker is OFF. Twist the two ground wires together and combine an 8 inch length of bare or green insulated wire with them in a wirenut.
Next, wire a new GFI plug in the new box. Connect the green wire from the wirenut to the green terminal of the GFI outlet.
Connect the plug's LINE terminals to the neutral and hot wires in the cable that you ran from the panel to the outlet box.
Now, connect the GFI plug's LOAD terminals to the neutral and hot wires in the cable that you removed from the panel and reinstalled into the new outlet box.
Secure the GFI outlet into the box and install the cover. Cover the electrical panel.
Power up and test. if the GFI trips, there's a ground fault in the circuit. If the circuit breaker trips, the circuit is overloaded.
Thanks for your comment. I operated multiple top loading washing machines for 25 years on this GFI breaker without a problem. However, the LG WM2016C, a front loader with a high spin rate and a direct drive motor, is apparently incompatible with GFI breakers. We have replaced the GFI breaker with a standard breaker and all is now well. However, I believe LG owes it to their customers to publicize the incompatibility in their literature and on their web site, and also to instruct their sales and service people accordingly. Currently this information is not available from LG without digging deeply and wasting considerable valuable time. It was not until the fourth service call, including a replacement of the main circuit board at LG's expense, that LG identified the problem.
Our friend has a new LG washer that repeatedly trips the laundry room GFI breaker. It also trips other GFI breakers. The old washer worked fine on the GFIC and another new (different brand) washer works fine. The LG manual specifically states that the washer must be connected to a GFI breaker, but the installer / service man recommended changing the outlet to a non-GFIC breaker, saying that the LG machine is not compatible with a GFIC breaker.
My friend is getting the LG machine replaced with another brand. In my opinion, LG should not be allowed to sell this machine until they fix their problem. Note that if you follow the serviceman's advice rather than the manual, you are responsible for any injury or death that might occur. This appears to be a serious defect in some LG washers.
