Kenmore Elite Oasis 27052 Top Load Washer Logo
Steve Posted on Oct 12, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Kenmore Elite Oasis Stops "error UL" Samll loads are problem now.
We cannot even load some cloths into washer without it making loud noise like it is rocking back and forth. Its really loud and seems like it might go through the wall before it eventually stops..
francoise cleofas
Level 3:
Genius:
  • Master 2,432 Answers
  • Posted on Oct 13, 2012
francoise cleofas
Master
Level 3:
Genius:
Answers
2432
Questions
0
Helped
298026
Points
6852
Check for a loose bolts and nuts that hold the motor .
5 Related Answers
Anonymous
  • 7 Answers
  • Posted on Aug 04, 2010
SOURCE: My Elite Oasis HE washer
call sears 1-800-659-7026 for recall information. Might be the circuit board issue...
Anonymous
  • 15935 Answers
  • Posted on Sep 11, 2010
SOURCE: UL ( unbalanced load ) signal appears, washer will not spin
Re-balance the load, and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Anonymous
  • 15935 Answers
  • Posted on Sep 25, 2010
SOURCE: Stops before spin with error code of LF
LF Error code: LF stands for long fill and occurs when the water level does not change for a period of time after the valves are turned on.
All washers are designed to operate with a water supply pressure of 20-100 PSI. When the pressure drops below 20 PSI the washer can have the following problems:
* Slow Fill- low water pressure reduces the speed at which water flows into the machine.
o Verify the pressure at all other water sources in the house (i.e. sinks, showers, etc..). If you find other places where the pressure is low, the problem is not with the machine but with the water supply.
* Continuous Fill- The valve may not fully seat under 20 PSI which would allow for a constant flow even when the machine is not supposed to be filling.
o Contact the water company to verify the pressure being supplied to the house.
* dispenser- Needs a minimum amount of pressure to function. May dispense constantly, at the wrong time, or not at all.
o A plumber may need to be consulted if the pressure is found to be too low.
Things you can check :
* Are the Hot and Cold water faucets turned on
* Are the water hoses kinked
o Make sure all the hose are straight and able to flow water
* Are the screen inside the water valve plugged
o Inlet valve should be free of debris and rust.
o Turn off water and remove the inlet hoses from washer.
o Remove any accumulated film or particles.
o Assure rubber washers are in the end of each inlet hose.
o Reinstall hoses, turn on water and check for leaks.
Error codes can be caused by a Power Surge or other electrical anomaly,attempt to return the washer to operation by following the Hard Reset procedure below.
1. Unplug or turn the circuit breaker off for 30 seconds.
2. Reconnect the unit to the power source by turning the breaker back on or plugging the unit back into the wall outlet.
3. Press the Pause/Cancel/Stop button twice to clear the display.
4. Start a short cycle to check the operation of the machine by selecting a cycle and pressing and holding the start button until the machine starts
Anonymous
  • 15935 Answers
  • Posted on Sep 26, 2010
SOURCE: Kenmore Elite Oasis HE 27072. Keep getting UL
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
Silverdragon
electronic & computer repair& servicre
  • 12061 Answers
  • Posted on Oct 31, 2010
SOURCE: I have a Kenmore Elite
Hi sounds like you may have a broken "Mount". You need a serviceman to repair this, if it is. In any case the best thing to do, will be to contact Kenmore, and arrange for a serviceman to call, and then ask for a 'Quote" before allowing any repair work, to commence.
Washing Machine Repair Manual FREE online - DO-IT-YOURSELF
Have a look at this DIY website above, it will be of some help. Spares below.
http://www.repairclinic.com/Kenmore-Parts
7helpful
2answers
My Kenmore Elite Oasis washer unbalanced signal seems to be very sensitive. Only after several tries of readjusting the load to get it really even that the washer will spin without stopping. I made sure...
If the washer throws an UL error code with out any clothes in the washer then the issue must be concerned with the mechanical alignment inside the machine or a bad CCU.
The most common problem which can cause this is some sort of mechanical hinderance which does not allow the basket to move freely.
The suspension system which holds the basket in its place might be faulty and causing the unbalancing. In this model i think there are plastic ring at the bottom of the basket . Even if they are worn out or moved out of position it may cause the UL error code you are facing
1helpful
I have a Kenmore Elite Oasis He. During the final spin cycle the load becomes unbalance and the drum beging jumping up and down until the UL code is displayed, this happens on every load except when empty...
UL = uneven load.
Re-distribute clothes and re-try.
If still no-go... the load balance sensor is likely to blame.
UL in digital display coming on during wash cycle. When washer is spinning during wash cycle it is very loud and the washer moves. We have had it repaired a couple of times. It will work for several...
Hi
Thanks for using FixYa. ULis displayed when the machine/motor control detects an off-balance load, and is steady on while the washer runs a mini-cycle to rebalance the load.
• Display clears if mini-cycle successfully rebalanced the load.
• If the mini-cycle is unsuccessful, uL will flash until the door lid is opened, allowing the customer to view and redistribute the load. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
My Kenmore Elite Oasis starting to show "UL" and immediately stopped working. How do I fix this issue?
UL = Unbalanced Load
re-distribute the clothes and re-try.
2helpful
2answers
What does UL code mean on washer?
What does error code UL mean on digital Kenmore Washer?
1helpful
4answers
Constantly off balance
I have a kenmore elite oasis top loading washer about 3 years old. I took it apart and checked the springs and the rods and the plastic ends that hold the rods in place and all of them look fine. I run an empty load in the washer and it still goes unbalanced on the spin cycle. My water bill has tripled due to the fact that every load takes 3 to 4 washings. I need help please!
3helpful
My kenmore elite oasis keeps stopping on spin and flashing ul it is a top loader king size capacity
UL = uneven load.
Alexander
vince
