Vehicle Parts & Accessories Logo
Posted on Sep 30, 2012
How to reset automatic sliding door on chevy venture van
2001 chevrolet venture van automatic sliding door
woodardjp
Level 1:
Problem Solver:
  • Contributor 13 Answers
  • Posted on Nov 02, 2013
woodardjp
Contributor
Level 1:
Problem Solver:
Answers
13
Questions
Helped
10166
Points
33
The rear side door actuator control modules monitor the power sliding door positions at all times. Whenever the battery positive voltage supply to a rear side door actuator control module has been removed or the on-board diagnostics have been activated the power sliding door system(s) must be re-initialized. Re-initialize the right or left power sliding door systems using the following steps:
  1. Turn the ON/OFF switch for the power sliding door system to be re-initialized to the OFF position.
  2. Manually open the power sliding door completely.
  3. Manually close and latch the power sliding door.
  4. Turn the power sliding door ON/OFF switch to the ON position.
  5. Open the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  6. Close the power sliding door completely using the B-pillar or overhead console OPEN/CLOSE switch.
  • Paul Bixby Nov 27, 2018
    helped a little, but still issues... embarrassed to admit that this did reveal that the off switch was the path to "manual door"... still having issues, but do not have to spend hundreds yet on a new motor. Thanks!
  • Mike
    Mike Apr 05, 2022
    Just what I needed to hear!! Just bought a 20 year old venture, disconnected the battery and the doors wouldn’t work. I thought something was messed up from also just having removed an alarm system (100 wires!)then this simple procedure fixed it, yay!!
Removal of front differential bearing on 2001chevy venture van
stop... don't take your van apart.... until you go to a auto parts store to buy a repair manual.. and read about how to remove the parts correctly ...
Location of return fuel line on 2001 chevy venture van viewing from top open hood.
My 01 Chevy venture just got a new fuel pump put in gas gauge still isn't working proper so had another fuel pump put in same problem. My relay fuse is good fuel pump fuse is good. I have to have my wires checked, make sure my sensor on top of pump connector wires are good. What else can I be looking for?
1helpful
2answers
Are parts from a 2001 Chevrolet Venture interchangeable with a 2003 Chevrolet Venture?
I can't say all the parts will be interchangable, however, a lot will be.
Chevy venture van passenger side AC blows cold, driver's side blows warm to hot
Usually a blend door problem, either the control or the blend door itself.
1helpful
I recently purchased a used 03 Chevy Venture van. The passenger sliding door doesn't open. It worked for 1 week and stopped. The driver side sliding door has a broken handle so I'm able to open that door...
Pain but fixable. Sounds like the linkage is not connected. Even a mechanic will have to remove the door panel and fight with it. If you can remove the rear seat from the drivers side side door then you might have room to remove the passenger side door panel to fix it. Usually clips are the first thing to break on door handle/latch linkages
2001 chevy venture van and i cannot turn the key
While turning the key rotate the steering wheel left and right. If there is too much tension on the parking lock the key cannot be turned.
1helpful
2001venture van service engine soon light stays on
most any sensor going bad can cause the check engine light to come on,try disconnecting the posative battery cable for 15 seconds ,then put it back on,will reset the codes, or take it to auto zone,they will test your computer for codes at no charge to you.i had a venture van my was ox. sensor. thanks robert b.
Reset factory alarm 1999 Chevy Venture
passager side lock and unlock the door try it out pierre
Top Chevrolet Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
ZJ Limited
ZJ Limited
Are you a Chevrolet Vehicle Part and Accessory Expert? Answer questions, earn points and help others
