Beeping sound coming from inside refridgerator
Unplug your refrigerator from the ac outlet, and 0open theref door for approx. 5 minutes. Then plug it again, after you hear the beeping close the door. wallah it's fixed.
This really worked. Thanks bennyc54!
My freezer kept beeping and had the red "door ajar" light on even though it was completely closed. Doing what you suggested finally worked, after trying everything else! Thanks!!!
Wow! This worked great! Thank you soooo much! I could not find one thing about this beeping problem in the book! Thanks again! Your awesome!=)
Please help I did what you said and it wont STOP.
was doubtful this would actually work but tried it and it hasnt beeped since...thanks benny
Benny, you're a rock star. I was up half the night doing everything I could imagine to kill that horrid noise. My teenage son had put stuff in the fridge that prevented the door from closing, and I fixed that, but even 9 hours later, the refrigerator was at the proper temperature, but it would not *******. Your trick worked like magic. Thank you so much. My son thanks you too, because he woke up to a not very happy mom, and we're all happy now!
You da man, Benny...it's 97* out & I REALLY need my fridge! thanks
OMG after cleaning refrigerator- shut the door! 2 hours later alarm started and would not stop!! Went to bed hoping just needed to cool back down but NO alarmed ALL night! Found Benny's probelm solved!!! Thank You! THANK YOU!!!
Benny, youre the best! the best!
5 minutes is longer than necessary. I unplugged for 30 sec. and the resolution worked for me.
Your are a rock star!!!!! TY I was very close to returning the dang thing!
BennyC54 is the man! It has appeared to work.
TY, TY, TY. Been beeping 5 times per minute for over 48 hours. Driving me nuts. Solution worked.
worked like a charm
thanks worked
Worked. Yahoooooooo. Thank you. Thank you. Thank you.
This is why I love internet...better and quicker than calling customer support for help.thank you Benny
THANK YOU!
Thank you. This worked! Thank God for the Internet.
BennyC54, can you tell me what caused the beeping?
my Frigidaire FFUS2613LP1 leaks water under the water dispenser.
Thanks! I turned off fridge to clean yesterday and awoke to find I'd forgotten to turn it back on. Upon turning it back on, it began beeping 5x/minute. Per your instructions, I opened the door and unplugged, then re-plugged with door open. Only waited 2 minutes, but it worked!! PTL!
Didn’t work
Thanks I just did the reset procedure you takes about it, Worked!! Power went out last night and darn thing kept beeping this morning and it was so annoying but the reset did the trick. I had no issues with it making ice or anything like that before there power went out.
My frigidaire keeps beeping and will not stop. Happened after the power went out. I have unplugged in and plugged back in and beeping noise does not stop. Manual talks about 3 beeps and 5 beeps, but mine beeps continually.
Our Frigidaire refrigerator wouldn't come back on after a brief power outage caused by our hydro company. It started to beep constantly and wasn't running. We followed bennyc54 instruction above and it worked. Unplug or turn off the power to the fridge via the breaker and open the door for 5 minutes, plug back in or turn power back on to the fridge from the breaker and when you hear it beep, close the door. Ours started up, the display lights came back on and the fridge was running normally again after a few minutes, maybe four minutes or so.
Thanks, bennnyc54, I had the same problem (5 beeps every minute)--that fixed it!
AND IF OPENING THE DOOR DOES NOT WORK WHICH IVE TRIED WHAT OTHER WAY
I have had this problem for years. I finally pryd the face plate of the climate control drawer and pulled out the computer cable that connects the face plate to the drawer. The face plate pressed right back on. Problem solved!
Hi, can you be more specific. I have a can-do attitude but very little experience with appliance diys. My fridge beeps continuously beginning 2 days ago, I have used the tip above 3 times in two days now. It works temporarily. Its been humid, also maybe power outages or surges. This house is new to us, we're not really moved in yet... the fridge is 2008 I believe. Any help is appreciated
Extremely humid july day... 4 month old side by side started beeping every 5 min after busy afternoon cooking for company. NO solution in manual, NO help via phone. Finally pulled it out un-plugged it and plugged it back in... Voila!!!!!!!!!! Fixed!
Thanks. Holding my breath. New control module after only 11 months. Overnight settling of frig and filled it and cleaned and started to cool food and then started beeping. Reset temperature in refrigerator side of unit and it wouldn't take. Turned power off to fridge, leaving door open for 5 minutes; closed door and reset temperature. I don't recommend Frigidaire brand after this experience.
Fred
i agree sisde frigdaire even after reice maker not maken ice , water valve now gos in defrost ! icebox 2015!!after 3 yrs old frigidaire peace junk!!!!! pass on !!!
Thanks.. Thi helped me today..
I have done everything in the comment. I've unplugged it.. No improvement. Beeping non stop. What can I do?? I can't seem to get a clear answer..
Our Frigidaire refrigerator wouldn't come back on after a brief power outage caused by our hydro company. It started to beep constantly and wasn't running. We followed bennyc54 instruction above and it worked. Unplug or turn off the power to the fridge via the breaker and open the door for 5 minutes, after the 5 minutes plug back in or turn power back on to the fridge from the breaker and when you hear it beep, close the door. Ours started up, the display lights came back on and the fridge was running normally again after a few minutes, maybe four minutes or so.
Thank you VERY much! I was so frustrated and ready to give up. Frigidaire helpline - not helpful; called a repair man - not helpful. Read your detailed responses - did it minute by minute and it worked! Thanks and God bless!
I wish this helped me. Mine is beeping 40 times per minute. Full fridge and freezer and I am so worried everything will spoil. I have done what is stated above and it has not helped any other suggestions?
This seems to have worked for us also - totally random but nice to have the beeping stop!
Okay if all else fails this is what you do this is what I had to do just unplug the refrigerator let it be for 5 minutes or so and just plug it back in don't open the doors don't do anything don't stand on your head nothing and it should fire right up kind of like a computer all else fails you unplug it plug it back in
Junk it....
Maybe the timer is bad and is not removing the frost, this heater work like 1 or 2 times a day, when ice build up inside the fridge back panel can do this to advice there is too much frost inside
Eurika.....it worked. Unplug for five min with the doos open and boom. On a side note, if the fridge is leaking water, then you have the vent frozen and it requires time to inthaw. You can doped up the process with a hair dryer. Best to clean behind your fridge annually to keep the ventilation system open. I vacuumed the whole lot area to remove all the dust and other stuff like cat fur. I am happy with my fridgidare.
Thanks to whoever posted this! My Frigidare fridge was beeping and the freezer worked well but the refrigerator was not cool (temperature didn't mark anything). Tried the unplugging, opening doors and waiting 5 minutes and when I did, refrigerator started working just fine and no beeping sound! Thanks again! ????
My 2 cents on this and based on my own experience is that something in the refrigerator is not right and the cold air vent is blocked or full of ice..
My problem is the display doesn't show up and it's a constant beeping noise. The fridge and freezer will not cool. I have unplugged it and plugged it back in. It reset and beeped 3 times and worked fine. Now I'm finding myself having to do this process sometimes once or twice a week to twice in a twenty four hour period. What's going on and what do I need to do.
My side by side frigidaire won't come on, just beeps
Any fixes on this problem
Our Frigidaire refrigerator wouldn't come back on after a brief power outage caused by our hydro company. It started to beep constantly and wasn't running. We followed bennyc54 instruction above and it worked. Unplug or turn off the power to the fridge via the breaker and open the door for 5 minutes, plug back in or turn power back on to the fridge from the breaker and when you hear it beep, close the door. Ours started up, the display lights came back on and the fridge was running normally again after a few minutes, maybe four minutes or so. Hope you found a solution as I know your remarks were in October and now it is January 2016!
same problem, beeps five times at 1 minute interval. Have reset it and nothing!
Keeps beeping 5 times every minute.
You da man Benny! Thanks so much!
Rock on, Bennyc54. We've had one problem after another with our appliances. Thank you for making this an easy fix.
@marc101us did u ever figure out how to stop it mine is doing that im going crazy
mine was doing it too..just started this morning ..i opened the door an unpluged it an waited 5 min an pluged it back in an it has stoped
FINAL ATTEMPT TO FIX intermediate BEEPING of continuous 5 beep cycles
Open the door, then Unplug your refrigerator from the ac outlet. 2) keep the door open for approx. 5 minutes. 3) Then while the door is still open, plug it in. 4) After you hear the beeping start, then open the freezer door also. 5) next time it starts beeping, close both doors in the middle of the beeping. It should immediately stop beeping. 5) wallah it's fixed. 6) You just reset the door ajar alarm.
Yes, the above worked for our fridge that was not turning back on after a power outage and it beeped continuously until we did the above.
thank you,i fallowed the steps above and it worked on our Frigidaire refrigerator
I can't believe a 4 month old refrigerator would need this kind of help after a power outage ..... I hope this remedy works but it seem like we purchased a true piece of JUNK to trust our Frozen food with.
I know this sounds crazy, BUT, our fridge beeped five times every minute. I put my phone in the fridge on video and the light was not going out so it thought the door was open. Taped the light toggle down, beeping stopped.
Not crazy at all! I had to pay a service fee to learn something similar. Modern reefers don't always have a toggle switch. Some have a magnetic sensor. The magnetic field can be interfered with by items stored on top of the unit. Mine was cookie sheets and chafing dishes. Light stays on/interior gets warmer/random temperature alarms for several hours. I'd have never figured it out, so it was $90 well spent.
