EPA regulations require a lean fuel:air ratio to meet emission standards. Lean mixtures causes engines to be more temperamental when starting and operating. Mixture adjustments on the carburetor, if any, commonly require special tools to fit the mixture screws.
The procedure I use with cold 2-cycle engines is to prime the carburetor if it has a bulb type primer. If it doesn't have a primer, it might require more pulling of the starter to get the carburetor pump to pull enough fuel into the carburetor before it will fire. Without choking it, pull it over several times. This helps to avoid flooding the engine if it already has enough fuel in the engine to start. If the engine is hot from being used recently, it might not need to be choked, and choking it can cause it to flood when the engine is hot.
If it doesn't start without the choke, then I choke it and pull it over 2-4 times to get it to fire, but it likely will not run very long with the choke on even if it does start. I then turn the choke off and pull it over to see if it will start. Partially opening the throttle while pulling the starter sometimes helps.
If the engine gets flooded, try holding the throttle open while pulling the starter. If it will not start, try removing the spark plug and wait before cranking it over to allow some of the fuel to evaporate before replacing the spark plug. Try to start it again without choking it, and hold the throttle open. If it does start, the throttle may need to be held open, at least partially, until excess fuel can be consumed.
These type of engines can be a real problem to start and operate. And any carburetor mixture adjustments, if any, are made hard to reach or require special tools to fit the mixture screws. Before I look to the fuel delivery system as the reason the engine doesn't start, I check to see if there is a spark at the spark plug after I take it out. There is probably another Q&A about checking for a spark, so I will not try to address that here.EPA regulations require a lean fuel:air ratio to meet emission standards. Lean mixtures causes engines to be more temperamental when starting and operating. Mixture adjustments on the carburetor, if any, commonly require special tools to fit the mixture screws.
I recently had a Hitachi RB24EAP blower that wouldn't start. It started easily when new and for a season of use. It gradually became harder to start, until it wouldn't start at all. It was partially disassembled, It required a puller to remove the rotor, which was tight on the shaft. The end of the crank on the ignition rotor end was tapered and had a Woodruff keyway cut into it. The rotor didn't have a keyway, but there appeared to be a sheared portion of the aluminum in the bore of the rotor where a keyway groove should have been.
An online parts diagram didn't show a key was required. The key must have been integral with the aluminum rotor. The end of the shaft is tapered and the designers must have thought the rotor would be tight enough to keep it from rotating on the shaft without a key. The key cast in the bore of the rotor was apparently there just to align it on the shaft for proper timing.
After cutting a keyway groove in the bore of the rotor with a jig saw blade, I used a Woodruff key to reassemble the rotor on the shaft. Now it starts like it did when it was new.I recently had a Hitachi RB24EAP blower that wouldn't start. It started easily when new and for a season of use. It gradually became harder to start, until it wouldn't start at all. It was partially disassembled, It required a puller to remove the rotor, which was tight on the shaft. The end of the crank on the ignition rotor end was tapered and had a Woodruff keyway cut into it. The rotor didn't have a keyway, but there appeared to be a sheared portion of the aluminum in the bore of the rotor where a keyway groove should have been.
You can't post conmments that contain an email address.
USA answers only
Blower in cab dead on all speeds even HIGH? not told.. and matters
is this manual HVAC or auto climate control option?
if only high works the blower resistor block is blown as most are this old.
what engine is there, fuse boxes change greatly by engine there.
the SM service manual covers this.
1995 is old car and books hard to find now, paper books back then.
books then are not in PDF digital format so find that is near impossible now, or for sure then.
all that is exits is crude documents, simplified drawings.like chilton stuff.
ok my online SM is the pits on his 1995 as is most cars that old
back in the non digital age of books. no PDF then
so here is Paper book answer, by one.
If you pulled the 10 amp fuse in the I/P fuse block and the blower still worked than the the blower motor module is most likely the problem. It is fed by a 30 amp fus4e in the fuse block under the rear seat. That fuse is always hot and always supply power to the blower motor module. If you pull that fuse and the blower stops than it's pretty likely the blower module is the problem.
The blower module is located near the blower motor. It is usually held in place with 2 screws and will have four or five wires at the connector.
Fist clean your computer of dust using a fine air blower from a compressor specifically around your central processing unit making sure there is no moisture in the air line
as dust will cause a lot of static which will make a computer overheat and cause lots of problems
Try replacinng all leads that are attached to your external hard drive then try uninstalling a few unnecessary programs then click start run type cmd then type chkdsk/f which will automatically fix any corrupt files on your hard drive then defragment your hard drive good luck with this
If it is under 2 years old, I would take it to a warranty repair center. The carburetor have been giving some problems so they have needed to be replaced because they are sub standard quality.
Sometimes blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Probably just a broken belt. Unplug the dryer and open it up (PIX BELOW) clean out the dryer and inspect the wheels idler and blower cage.The belt is probably gone after 10 years. Here are some repair pix
Check the blower fan which is mounted underneath the drum on my DLE2514W front loading LG dryer. I experienced poor drying along with a loud thump at the start of each cycle. At first I thought it was a bad roller but later found that the blower fan had separated from its bracket so it was not turning with each turn of the moter but rather spinning freely.
it could be any number of things, sounds like its possibly a virus so a reformat would be needed, but it also sounds like the hard drive could be dead, boot into the bios and go to the tab labeled diagnostics and select first the short scan then the extended if either fail HP will replace it if its in warranty if not they are about 60 bucks online in most places (sometimes even less!!!) i have seen over a hundred of these in the past year, take my advice :)
