Starts wash cycle but doesnt finish as stops part way through wash. Will fill and rinse on rinse programme and will also drain when put on drain programme. wont spin though. end light flashes five times and start/pause light flashes twice Any ideas? have cleaned out the front filter
SOURCE: AEG Lavamat w850 not finishing cycle! help!
check no kink in drain hose and if plumbed in unbder sink, check spigot into sink drain is not blocked. put drain hose lower down band check there is water coming out freely. if not, then suspect something trapped in hose from tub to pump
SOURCE: aeg 76669 oko lavamat machine not
I have had the same problem. If you switch the machine to off and then to cotton/linen 95, then press at the same time prewash, soaking, qick wash and stain buttons for 10 seconds switch it off. When I switched it on it worked.
SOURCE: AEG 72640 stopping mid-cycle no error code showing
I have the same problem with my Oko Lavamat 74639 Update. I've tried changing the vacuum sensor, but no luck.
Did you get your fixed?
Olafur
