Sony Cyber-shot DSC-W30 Digital Camera Logo
Anonymous Posted on Dec 19, 2008
File transfering problem
I have a Sony Cybershot DSC-W30 camera,which i can't transfered any videos.But pictures are transfered.All format was not supported.So, this time what can i do? Please give me a good answer
Anonymous
Level 2:
  • Expert 63 Answers
  • Posted on Dec 19, 2008
Anonymous
Expert
Level 2:
Answers
63
Questions
0
Helped
16876
Points
147
Http://www.videolan.org/
Need usb transfer cable code or number for a sony cybershot n50
I believe you are looking for a USB transfer cable for your Sony Cybershot N50. I found a replacement USB camera transfer data sync charging cable cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300, DSCW370, DSCW800, DSCW830, DSC-H200, DSC-H300, DSC-W370, DSC-W800, DSC-W830 digital camera on Amazon . This cable is compatible with several Sony Cybershot models, including the N50. The cable is priced at $7.95 and comes with a 30-day return policy. Amazon.com: Replacement USB Camera Transfer Data Sync Charging Cable Cord for Sony Cybershot Cyber-Shot DSCH200, DSCH300,DSCW370,DSCW800,DSCW830,DSC-H200,DSC-H300,DSC-W370,DSC-W800,DSC-W830 Digital Camera (Black) : Electronics
Video no longer transferable to PC
One of the most important things for transfering files from a camera to a computer is the software installed on the computer. Perhaps you did forget you installed this when your camera was new. The software came with the camera.
Try reinstalling the software that came with you camera, or us an external memory card reader. You don't need extra software to transfer the file from the card to your computer, but you still need software to play the video. You also could try to install a free video player like gom player. There are more free players. There are so many different video formats, so chose one that can play lots of different video formats, if you don't have the Sony CD or DVD.
HI DID YOU FORMAT YOU MEMORY CARD AND TRY AGAIN TO TAKE VIDEO AND TRANSFER TO PC.
2helpful
Sony cybershot P200 says 'File Error'
The LCD screen may display a FILE ERROR message when trying to view a still image on the camera if the image was rotated, modified and overwritten using editing software on a computer. To play images you have taken on the camera, it is recommended that you do not make any changes to the original image files. I suggest that you transfer the images from the Camera to the computer and check if it works. After transferring the images, get the Memory formatted from the Camera and start capturing new images. The edited images will not get displayed in the Camera again. Please try not to edit the images in the Computer without transferring it.
Thanks.
KenSolutions
FixYa
1helpful
File error
It is picture file that stops file transfer function, delete that picture and continue or go to memory card through my computer > mass storage drive and delete that file or copy rest of files and past in computer some where like my documents etc.
That particular picture file DSC03270.jpg is incomplete/ corrupted and causing problem in files transfer operation. Either delete it or bypass it and transfer rest of files from camera.
After transferring files to computer, format memory card to avoid any problem in next time as option would be in camera menu.
Let me know if you have additional question.
Thanks.
Sony cybershot DSC W30 buttons fail
take the battery out and let the camera sit for an hour or two, take out the memory card, try to view photos on computer, if it does not work, you will have to format the card and start over. Some times when the format on the card is bad, the camera will not work properly. I have two cybershots myself.
Sony cybershot model DSC-W30
Sony Camera Website:
http://esupport.sony.com/US/perl/swu-list.pl?mdl=DSCW30
Transferring PC videos TO a Sony Cybershot?
It probably won't work but here is something to try: Make a short video clip with the camera. Then look at the memory stick with the computer to find out the name of the video and what folder it is in. If the camera makes .avi videos, you will have to convert your home videos to the .avi format. Then rename the video to a name similar to the one the camera made. i.e. If the camera named its video Vid00023.avi, then you should rename you home video to something like Vid00034.avi. Then put your video in the exact same folder where the camera put its video. That will give it a chance to be recognized by the camera. But I doubt it will play in the camera.
Top Sony Cameras Experts
ZJ Limited
ZJ Limited
Are you a Sony Camera Expert? Answer questions, earn points and help others
