When I plug in my gutter maker motor to my gen it pops braker in 15 mins. If I hold braker in it trips the groung fault.Never done this befor.It is a dewalt 7500.Any way I can fix this.I dont use the genarator that much.Thanks for any help you can give me.George
The ground fault it orgnal equiment on genrator.all of them are groundfault.But will try to see if it is mosture on motorThe ground fault it orgnal equiment on genrator.all of them are groundfault.But will try to see if it is mosture on motor
You can't post conmments that contain an email address.
GFI's and motor's don't get along with each other,if the motor is just the slightest bit of any moisture,the GFI will pick it up as a ground...Try to run it without the GFI.
Do you have anything plugged in? If they keep tripping with nothing plugged in I would call a electrician to troubleshoot or replace the breakers. They may still be under warranty from Siemans.
it could have a small leak to ground on it,,, thats why it trips the brakers,, on a higher braker the leek off also needs to be higher than 50milly amps to trip the braker,,, this unit uses 13 amps
you need to run this compressor on a cooker trip (ei:30 amp) it pulls far to much power for a house hold trip (ie:15 amp) even if close to a 13 amp plug, at 375 feet???? thats some loss in the wire, over 50%!!!!! if it trys to start on the low loop.s it pops your trips!! right? hook it up to your cooker trip, but its still a very long hick for your power to get to,,
ps,,,this compresor never come with a three pin plug on it did it? like 3.7 hp = 4000 watt's app at the plug!
you could try puting a bigger starter (cap) on the motor that will hold more amp's for starting up on
and it will give your motor a longer,,,kick start,,,
talk to your frendly sparky first! ("caps," can and will kill you, if you tuch a charged up one!!!! so dont play with them) hope this helps you out
1) Try with a different surge protector. The oine you're using could have a short-circuit
2) Try without a surge suppressor, at least for a day
3) Does the circuit breaker trip when something else starts running? Your microwave, fridge, dishwasher, etc.?
4) Check the user's manual of your TV, under SPECIFICATIONS. Check for "POWER REQUIREMENTS". If the power requirements listed is greater than 15 Amps or 1,700 Watts (assuming you live in the USA and your household is 110-120V), then the circuit breaker will almost always be triggered by the TV. Most circuit breakers inside a house are 15 Amps.
The only option you have is to replace the circuit breaker for one that has more Amps, but doing so on your own without having and electrican check if the wiring will hold the extra load is extremely unadvaisable. You may end up with an electric fire in your hands.
Hi - Go to the Bunn website, www.bunn.com , and click on their Customer Service link. I seem to remember a recall for that problem. You can call their toll-free number or write to them from their website via the CS link.
unlikely a fault with dryer. try plugging another high consumption item into the socket you use for the dryer ie elec kettle or iron. see if breaker still trips and if so you have fault in socket or house wiring. if you put a plug on the dryer yourself, check you have wired plug correctly
