I ran the spin cycle with no clothes in it. It still abnormally spins out of control. It shakes so much, that it rubs onto the inner plastic around the drum and shreds it.
This could be an indication of a broken or cracked spin basket (spider) arm. The inner (steel) spin basket basket should not vibrate against the outer tub shell at all. The rear supports of the basket are made of aluminum and can crack or break. When this occurs, the basket will spin out of balance and vibrate against the outer tub shell. Using is long term in this manner will cause further damage. The only solution is to replace the spin basket.This could be an indication of a broken or cracked spin basket (spider) arm. The inner (steel) spin basket basket should not vibrate against the outer tub shell at all. The rear supports of the basket are made of aluminum and can crack or break. When this occurs, the basket will spin out of balance and vibrate against the outer tub shell. Using is long term in this manner will cause further damage. The only solution is to replace the spin basket.
You can't post conmments that contain an email address.
THIS IS CALLED A BEARING JOB THE INNER TUB AND THE OUTER TUB HAS TO BE REPLACED THESE PART ARE USALLY UNDER THE MAN. WARRANT BUT THE LABOR IS PRETTY EXPENSIVE ON THIS JOB BECAUSE THE WHOLE WAHER HAS TO BE TAKEN APART
check to make sure it is sitting level on the floor and one leg adjuster hasnt backed in making it shake. But even when you stick cloths in evenly they can bunch up during cycles.
Hello. Noises are common when using a two-in-one washer and dryer, as clicking or whirring is part of the cleaning process during the transition to the next cleaning process. The GE Spacesaver washer and dryer combo uses a top-loading washer stacked beneath the front-loading dryer, and uses an agitator that makes noises throughout the spin cycle. Although whirring or clicking is normal, other noises or malfunction indicates a problem with the washer that requires minor troubleshooting. Professional repair is necessary if the washer continues to experience problems during the spin cycle, as there may be a problem with the washer's agitator. 1 Open the washer's door and check the balance of the load's clothes. Clothes that are unevenly distributed around the agitator cause excessive shaking and result in an imbalance during the spin cycle. Reduce the load's size by removing clothing if the washer's drum is overloaded. 2 Push "Start/Pause" to pause the spin cycle and turn the washer's cycle knob to the "Off" position. Turn the knob to "Spin Only" and press "Start/Pause" to reset the cycle. 3 Turn the wrench counterclockwise or clockwise around the unit's legs to adjust the appliance's balance. The legs are adjustable with the help of a wrench to ensure the unit does not shake while in use. An unleveled unit shakes as it spins, and causes excessive squealing or rattling as it attempts to dry the clothes. 4 Touch "Start/Pause" on the front of the washer's control panel and unplug the washer/dryer unit's power cord from the electric oultlet. Wait two minutes and plug the power cord back into the electric outlet. Push "Start/Pause" to resume the spin cycle. Thanks.
During the spin cycle if your cloths are too heavy on one side you will get this problem, reposition the cloths and it should cure the problem, at least thats what I do when my machine gets to shaking.
When the washer goes into spin cycle it is suppost to start at a slow speed and continue to increase speed (to a maximum of 800 RPM) as the water leaves the clothes. Your washer is going directly to 800 RPM which causes the washer to shake and stop giving you the E4 code. The control board that controls this speed increase must be replaced.
y shaped piece that contains the spindle that attatches to the basket and allows it to spin is corroded and cracking. you can't buy just the spindle bracket, you must buy the basket too. you'll be buying the front part of the drum too, if you wait to long.
Not sure what you did, exactly. First, does the machine shake when spun empty...and then with water only? If so, you have probably failed to tighten something or misaligned something. Go over your work.
No shakes? Rearrange your load. You may have a pair of heavy wet jeans which is throwing the whole thing out of kilter. It only takes about a half pound of sodden clothing to do this.
