SOURCE: G-110 deck belt keeps jumping off pulleys
check for a broken belt tension er or maybe grass clippings under belt area, check for a broken or loose pulley bearing, even a bent shaft on the deck.
SOURCE: Swisher 60 deck belt breaks after mowing about 15 minutes.
Even though the routing is correct, have you checked that every spindle and idler pulley turns freely? These bearings can freeze up or bind because debris builds up in them. Also, if the bushings on the idler pulleys can wear, causing them to misalign. Keep checking. Also - is the belt snapping clean, or do you see a burnt, worn spot?
Testimonial: "Thank you for your help. The belt is snapping clean. You are correct in your assessment to what the problem might be. We checked all the above and did not correct problem. We put three washers on top of small idler pulley to bring it down and better align routing. Bought heavier belt at auto parts. Believe the bolt head was touching belt where it routed throught to larger idler pulley."
SOURCE: belt constantly breaks on my
what type of belts are you buying? there is a difference...mower belts are laid in rings one on top of the other sometimes with woven outer layer...normal vbelts are rubber with layer on top, and wont run a revs get too hot and fail....
