On Electrolux washing machines error e54 means the problem in the contact group of one of the two reverse relays. I would like to help you with the e50 error. What is your model of the washing machine?
You have not specified Tumble dryer model so I can not say for certain that my answer is correct. Fault codes can sometimes vary depending on the platforms appliances because today some manufacturers release new models twice a year and thay have the absolutlly right to make changes and improve the efficiency of new appliances (also change fault codes).
TEST this steps and fix it. This error code is E54 which is something to do with the motor.What
you can try first is pull machine out and take off the back panel. From
there you will see the motor at the bottom. Unplug the wiring block
from it and start the machine again.
E54 is a fusing error. You can attempt to reset the code by entering service modes. To do that, you press CLEAR MODES key, then the numbers 1, 0, and 7 and then hold down STOP key. Once in service mode, press 97 then #. That resets the code. Power the machine off then back on to see if it comes back. If it does, then you may need main board or AC driver board.
The one crinkled at the end on the left door is the problem.
Since it jammed it stops the whole copying process, ( you were most likely doing duplex)
The reasons for the crinkled paper are
1- the fingers or claws at the exit are worn and catch the paper instead of sliding them out.
2- you are copying something that has a black edge and is getting caught on those fingers ( or claws)
3- The rollers at the exit are in bad shape :
anyway check out this link and go to error codes :
