Hope someone can help me. I have lost my user Manual for the Kenmore Elite HE4t Smart
When I set my washer to work, it acts like it is going to start, it does a few clicks and then I get the error code DL and F flashing. I think it is something to do with the door, but the door etc. is closed and everything seems fine. Has anyone had this problem and if so what is the solution.
Also does anyone know how I could get another user manual for my washing machine.
thanks
Dee
The link in this reply goes no where "page not found or page error". Sounds like a helpful website is there a different link?The link in this reply goes no where "page not found or page error". Sounds like a helpful website is there a different link?
You can't post conmments that contain an email address.
This could probably help you................... till you get a new door mechanism to replace your door lock/switch. Which is available on the net, quoting your make and model. And which you can easily fix yourself.
Hi! ricksmith What is the first three digits of the model number. The he4t I have reference to does not have a "F" code error. Most of the codes are two digit, PF, F1 to F9 etc. You could try: Pressing Pause/Cancel two times to clear code. As well as unplug for 20 seconds. Do you have power fluctuations in your area. InMrFixIt
possible electronics failure. my HE4t has completly gone dead at the control panel after displaying error codes. A class action law suite is in the works on the HE3t HE4t machines.
The code "dl" stands for "Door Lock". This was a problem with my machine also. Check to make sure you are only using "HE" type of detergent. In the manual it states that using other detergents than high efficiency will cause computer board miscues.
Unplug the machine for a day or less, then try again. This worked for me for a while. It finally failed (I was using detergents other than all HE) and a repair man reset the washer. This happened last month (June, 08) and now I only use HE and the machine works great.
