Starts spinning and then stops ?
Possible fault in the motor , the bearings the drive belt or there is friction on the drive shaft.
Please check these links for tips:
Bearings check
Drive Belt
SOURCE: AEG lavamat 6955 sensorlogic, was showing F2,nowF3
Waited half hour; on start up F3 had cleared..pump overheat? Suspect sticky pump bearing..new pump.
SOURCE: aeg 72630 won't spin
most likeley cause are worn out carbon brushes in the main motor. have you seen any error codes e52 relates to the motor brush problem. e20 is inefficent draining caused by blockage in the pump chamber acces in the plinth area/ or in hoses or drain connection
SOURCE: My AEG Lavamat W 1000 runs properly but won't spin
a little late to solve your problem...if it ever happens again, change the 16 micro farrad capacitor in the upper rear right corner of the machine. This capacitor controls the starting torque in any motor mode
SOURCE: my aeg washing machine has
Hi.
Check if there is drain blockage. That will result in cycle not advancing to spin. To check drain system, check drain hose at the back and access drain filter in front.
If there is no drain problem, check pressure switch and lid switch.
Here a general article that I wrote about no-spin problem: If you have no spin ...
Regards.
Ginko
Initially starts spinning then stops
Problem with the Timer
Thanks
David
