Cars & Trucks Logo
Anonymous Posted on Jun 28, 2012
How do I bleed the radiator in my C70 Volvo ? you can bleed a radiator in a C70 , rite ?..
Marvin
Level 3:
Top Expert:
  • Cars & Trucks Master 85,242 Answers
  • Posted on Jun 28, 2012
Marvin
Level 3:
Top Expert:
Answers
85242
Questions
28
Helped
29034248
Points
266281
  1. This method works best if the nose of the car is raised as high as possible. Park your car in your driveway. Let your car cool down. When your car is cooled down, you are ready to work on the cooling system.
  2. Open the hood of your car. Secure the hood with the safety handle. If you have a newer car, you should have a bleeder valve on the front of your radiator. Check in your owner's manual for the location of this valve. If you do start your car, open the valve with wrench and let your car heat up. The excess air will bleed out of your cooling system. Keep your car on long enough to give the (trapped air) time to bleed out of your system.
  3. Let your car cool down. Once the car is cool, take off the radiator cap. Did the level of the radiator fluid go down? If it did, it means you bled the air out of your cooling system. Replace the radiator fluid, turn on the car, and let it run. Replace radiator fluid as needed.
  4. Step 3 (above) is the way you will remove air from your cooling system if you do not have a bleeder valve on your radiator. You will leave the cap off the radiator. You will run your car until it heats up. As the air dissipates, the radiator fluid level will go down. You will fill up your radiator fluid to the correct level. Be careful because the heated radiator fluid will be hot. Always wear leather gloves and safety goggles when working on your radiator.
  5. Once the air dissipates and you fill the fluid, shut off the car. Let the car cool down. Once the car is cool, put the radiator cap back on the radiator. You may have to put more radiator fluid in the radiator. The level may fall as the car cools down. Now it is safe to drive your car. You have removed the trapped air from your cooling system.
2 Related Answers
Anonymous
  • 33 Answers
  • Posted on Aug 18, 2009
SOURCE: Miles to kilometers on A volvo C70 MY08
yes you can change miles to km but only with volvo scan tool to reprogram it nothing that you can do home
Anonymous
  • 31 Answers
  • Posted on Jul 04, 2010
SOURCE: Change miles/gallon to liter/kilometer Volvo C70 My08
using the controls on your center console enter the menu and then car settings and you should be able to change the units of measure there
2012 Volvo C70. Where is the dip stick on the automatic transmission.
Question edited for clarity.
Question moved to model category.
2012 C70 Transmission Dip stick where is it?
Volvo Forums https://volvoforums.com > ... > Volvo C70
Jun 24, 2020 - the newer Asins like the 6 and 8 speeds use a dual drain plug design where the inner plug is removed to set the level via an overflow tube and ...
Finding the Automatic Transmission Dip Stick - Volvo Forums
Jan 11, 2009
Transmission dipstick/filler location? - Volvo Forums
Apr 11, 2009
C70 transmission fluid - Volvo Enthusiasts Forum
Sep 23, 2018
Transmission Fluid Dipstick Location - Volvo Forums
Feb 18, 2017
More results from volvoforums.com
Older models had a yellow dip plug.
2answers
Where is the fuel pump reset button on 1999 volvo c70
There is no reset button on a C70 Volvo, or any other Volvo for that matter.
1helpful
Volvo c70 2001. blown engine. Have now replaced engine/used old throttle body but car difficult to run and hard to start. surging badly will not idle/stalls
on google:
2001 Volvo C70 Problems - RepairPal
repairpal.com > Problems > Volvo > C70 Problem with your 2001 Volvo C70? Search our list of user submitted and RepairPal verified problems and issues
1helpful
I need to find a guide to replacing the radiator in a 1997 Volvo S90 w/ automatic transmission.
Volvo 1990-1998 Repair Guide
Radiator - REMOVAL & INSTALLATION
Perform this work only on a cold engine.
  1. Disconnect the negative battery cable.
  2. Set the heater control to MAX heat.
  3. Remove the expansion tank cap.
  4. Place a suitable drain pan into position. Open the **** on the right-hand side of the engine block. Fit a hose to the **** to collect the coolant. Open the radiator draincock.
  5. Close the drain cocks when the coolant is completely drained.
  6. Remove the cooling fan.
  7. Remove the cooling fan shroud.
  8. Disconnect the upper and lower radiator hoses
  10. On vehicles equipped with automatic transmissions, disconnect the transmission oil cooler lines at the radiator. Plug the lines immediately. Catch the spillage from the radiator in a separate pan.
  12. Some vehicles are equipped with a temp sensor on the drivers side top of the radiator, if equipped remove the connector.
  13. Remove the radiator retaining bolts and brackets.
  15. Remove the radiator assembly from the vehicle.
On 850/C70/S70/V70 models, the radiator comes out the bottom of the vehicle.
To install:
  1. Place the radiator into position and install the retaining bolts.
  2. On automatic transmission vehicles, connect the oil cooler lines.
  3. Install the fan and shroud.
  4. Install the lower and upper radiator hoses.
  5. Connect the expansion tank hose. Make sure that the overflow hose is clear of the fan and is free of any sharp bends.
  6. Fill the cooling system through the expansion tank, with a 50 percent antifreeze, 50 percent water solution.
  7. Connect the negative battery cable.
  8. Run the engine until normal operating temperature is reached.
  9. Bleed the cooling system.
  10. Check for leaks.
  11. Top up the cooling system, as required.
  12. Replace the cap.
  13. Check and top up the automatic transmission fluid level.
Hope thats help (remember comment and rated this).
1helpful
Milage between cambelts?
Mileage on timing belt, depends on year ? make (volvo) model (c70) and engine size?. heres a couple of mileage readings,the 1998 c70 with a 2.3 turbo engine is due every 70,000 miles. the 1999 -2001 c70 with 2.3 turbo is due every 105,000 miles. the 2002- 2004 c70 with the 2.3 engine is also at 105,000. the 1998 c70 with the 2.4 engine is due every 70,000 miles. the 1999-2001 c70 with the 2.4 engine is due every 105,000 miles. the 2002- 2004 c70 with the 2.4 engine is due every 105,000 miles. god luck hope this helps.
2helpful
2answers
WHERE CAN I GET A FREE HANDBOOK FOR THE 1999 VOLVO C70
you will need to pay for any book, there's nothing free on a volvo.
2answers
you need a scan tool that will access volvo modules go into cluster module and change over
1helpful
2answers
Automatic transmission
its red in color and its usually on the rght rear of engine/ Please rate my response thank you very much
Top Cars & Trucks Experts
ZJ Limited
ZJ Limited
john h
Arnie Burke
Arnie Burke
Are you a Car and Truck Expert? Answer questions, earn points and help others
