Samsung LTN4235X/XAA 42 in. Plasma Television Logo
Fabian Cordoba Posted on Mar 30, 2012
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will a power supply for a 50" plasma TV work with a 42" plasma TV?
Raja Musab bin Khalid
Level 2:
Mentor:
An expert who has written 3 tips or uploaded 2 video tips.
  • Expert 97 Answers
  • Posted on Mar 30, 2012
Expert
Level 2:
Mentor:
Answers
97
Questions
0
Helped
21486
Points
283
Sir it will work with your TV..
Abctay.com
Level 3:
Master:
  • Samsung Master 372 Answers
  • Posted on Oct 30, 2019
Abctay.com
Samsung Master
Level 3:
Master:
Answers
372
Questions
Helped
212248
Points
1385
If you need tv power supply board ,you should have a look this site :https://www.abctay.com
5 Related Answers
Anonymous
  • 1077 Answers
  • Posted on Jul 20, 2009
SOURCE: AKAI 50'' Plasma PDP5006H Main Power Supply Board p/n LJ4400057A
I looked around for a power supply for you and turn up nothing. I see your problem. Nobody is selling. Best just to fix the board itself.
What I would do is get a Service Manual over the internet. Nodevice.com is selling the Service Manual. Usually cost under $20. It will help you diagnose the source of the problem and fix it by soldering in the new part. The Service Manual will give you circuit diagrams, schematics, test points, and part number lists. And most cases the new part cost less than $15 by searching on the internet with the part number.
It's possible that it's just a bad capacitor or transformer on the power supply board. Cheaper than replacing the board.
I hope I solve the problem for you.
pizzaguy3274
Kevin Couronis
  • 4 Answers
  • Posted on Apr 12, 2008
SOURCE: 42fd9954
Not a fix, but it got my tv on.
I removed the back and tried the power switch.
I located the relay that was clicking.
I have two blue relays in the middle of my power board.
I placed a hair dryer over the relay for a few minutes.
After four tries of the power switch and it stays on!!!!!
Heat keeps the relay from just clicking off.
I don't know why.
This will at least get the tv on though.
A
Anonymous
  • Posted on Jun 22, 2008
SOURCE: spn4235 42" Samsung Plasma 6 years old
you can get the power supply and/or the service manual (with schematics included) here.
http://www.samsungparts.com/search/search.asp
Anonymous
  • 30 Answers
  • Posted on Jul 21, 2009
SOURCE: power supply is bad on philips plasma 50 inch tv, it just clicks
nice job... thats the most common problem with all LCD tv's now
Anonymous
  • 335 Answers
  • Posted on Nov 03, 2009
SOURCE: Samsung FP-T5084 No picture
For a 50 inch plasma....its worth it, in my opinion y-boards cost around $149 to $189
Testimonial: "Thank you. your feedback was appreciated. Theres a lot of value in getting an expert opinion whether to fix or not to fix."
My Hitachi tv model p42h401a will not turn on. The "standby"light is not on either. I have checked the power supply and that is working.
Have you opened the actual TV and checked the power supply board inside? Because that is what it is. You need a new one.
1helpful
2answers
2006 42" plasma has blank
Plasma and LCD TV sets are prone to having capacitors in the power supply section fail. This is the most likely cause for the probem you describe. When capacitors fail your will commonly see one or more of the following symptoms.
  • No video, Power light is on or blinking.
  • TV is making a clicking noise.
  • TV takes a while to come on
  • Screen is very dim or flickers.
Again, You can get a power supply repair kit with the parts, detailed instructions, and support from sites such as www.TvRepairKits.com . Or just click here to see more details on their kit.
Here are pictures of capacitors...Notice that the ones below look bloated. They have failed and will need to be repalced.
Capacitor being replaced! Fairly easy DIY fix.
8helpful
50" lg plasma tv will not power up
The problem with the set is bulged electrolytic capacitors in the power supply.
4helpful
2answers
My 50 inch samsung plasma tv turns off and on by itself. it also clicks while this happens.
My Samsung 52" plasma TV will shut off while watching TV. It will do it repeatedly and we have to turn it back on. Is it overheating and shuts down? How can this be fixed?
1helpful
2answers
Plasma 50" acts like it has no power
is the main power switch on @ the bottom if so could have bad main fuse,or power supply bad
Missing power cord
HELLO AND NO YOUR AMP SUPPLY IS'NT THE RIGHT AMOUNT YOUR CORD ONLY SUPPLIES 2.5 AND YOUR T.V. CALLS FOR 5.2 IT'LL RUN YOUR T.V. BUT THE REASON IT WONT WORK IS BECAUSE YOUR T.V. WILL PULL 5.2 AMPS AND YOUR CORD IS ONLY RATED FOR 2.5 IN TIME THE CORD WILL BURN OUT OR GET HOT AND CAUSE A POSSABLE FIRE.
Hp parts
are parts for hp plasma tv as hard to find as ive been told need a y buffer upper board for 50 inch plasma
1helpful
2answers
Power supply for lg plasma tv
i have a 60 inch tv i just order the power supply kit i want to install it myself do i have to open the whole back of the tv.
42" Toshiba Plasma TV no picture or sound
My experience with 42" plasma tv's with no picture or sound was a missing power supply voltage. On the power supply board check voltages on the plug. The voltages should be marked on the board,
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
